omega 24 v6
posted on 20/11/07 at 07:27 PM |
Key info
Hi hope someone can help me with this.
I need to get 2 keys for a flat made/cut/supplied. However the keys are security keys for the main door entry and the flat door entry. Each of the
tenants of the block has a key which fits the front main door but only their flat door(as you'd expect).
The key has code words on it and" 2/2" I take this to mean key 2 of two keys??
Anyone I've taken it to says they can't/won't cut it cause they got a "Pat Protected by Law" and a makers name on them
that I can't trace.
So how do I get a key??? Other than having to get a complete set for all the other flats as well (this ain't gonna happen).
tigertom
posted on 21/11/07 at 12:46 PM |
u'll need to get the lock manufacturers name and go straight to the supplier.it can be done but its not straight forward as there is a security
issue.thats the jist of it.
matt_claydon
posted on 21/11/07 at 02:33 PM |
Patent protected key blanks can only be supplied by the manufacturer, you'll need to get in touch with them or an agent directly. Who is the
manufacturer?
omega 24 v6
posted on 21/11/07 at 07:28 PM |
Manufacturer is NT Laidlaw. I did a search last night and emailed 3 companies dealing with them and so far no replies![](/images//smilies/mad.gif)
Confused but excited.
posted on 21/11/07 at 08:19 PM |
As a tenant, you should be able to get copies of them from your Landlord.
omega 24 v6
posted on 21/11/07 at 08:28 PM |
Sorry should have said I'm the co owner and have 2 keys each of my daughters have 1 each and I'd like to have a spare just in case.
posted on 22/11/07 at 12:25 PM |
change locks?
if you can buy blank, then file out yourself, assuming it is Yale type key.
