New Topic New Reply
Author: Subject: Coil-Over dampers
Gremlin
posted on 11/6/08 at 07:06 PM Reply With Quote
Coil-Over dampers
Starting to pull parts together for my Indy build and hoping to get some Coil-overs for farthers day! ?
Sizes I have seen for other sevens are 13inch open 9inch closed. 350lb per inch front and 200lb per inch rear.
Is this the sort of thing the Indy uses?
Does it make a differnece if I go Indy or Indy-R or are the coil-overs the same?
EZy GreMLiN
"The only way to get rid of temptation is too give in to it..!"
philw
posted on 11/6/08 at 07:14 PM Reply With Quote
I would have thought 225 front 180 rear, i'm sure somebody with an MK will be wiser.
for road use that is
[Edited on 11/6/08 by philw]
Must try harder
Gremlin
posted on 11/6/08 at 07:33 PM Reply With Quote
Forgot to say im using a bike engine possibly R1 or if i save hard ZX12 or similar.
Oh and 80% will be road use and maybe 20% or a bit more track.
[Edited on 11/6/08 by Gremlin]
EZy GreMLiN
RK
posted on 11/6/08 at 09:27 PM Reply With Quote
If you want some springs for 1.9" ID ProTech: 300 and 200 lb, let me know.
Gremlin
posted on 11/6/08 at 09:33 PM Reply With Quote
Will be looking for front and back complete kits once I know what Im looking for..
Thanks anyhow.
EZy GreMLiN
posted on 12/6/08 at 07:43 AM Reply With Quote
You need to choose Indy or Indy R chasis first. By all accounts this is not a difficult choice.
Once decided you need to speak to MK themselves about what you need based on your choice of motor BEC or CEC. You may even find they have exactly wat you need at a good price too.
Gremlin
posted on 12/6/08 at 08:59 AM Reply With Quote
Ok thanks.
From the questions I have asked and reviews I have received I'm sure it will be the Indy-R.
EZy GreMLiN
New Topic New Reply
