Author: Subject: Aftermarket ECU with variable valve timing control option
Steelman
posted on 14/10/08 at 07:37 AM Reply With Quote
Has anyone fitted a aftermarket engine management system with a variable valve timing control option on it. I am fitting a nissan 300zx z32 V6 into a Luego Viento.
tonym
posted on 14/10/08 at 07:47 AM Reply With Quote
VVT
Yes I have an Omex ECU on a Toyota Vvt 20v engine. Just use the shift light facility to operate the Vvt. This probably applies to most other ECU makes out there.
HTH
tony
bimbleuk
posted on 14/10/08 at 08:11 AM Reply With Quote
The OMEX ECUs can do infinite variable VVT as well. Not specifically listed on the ECU spec but basically you use a pulse width auxillary output to give you the variable control.
PAUL FISHER
posted on 14/10/08 at 09:36 AM Reply With Quote
"chris mason" on this forum fitted a stand alone ecu on his s2000 Indy to control the variable valve timing/vtec,I think it was a "hydra" system,it brought the vtec in lower down the rev range,so the power came in a bit softer,to make it more driveable.
Ham
posted on 14/10/08 at 10:50 AM Reply With Quote
Check out www.gotech.co.za used by plenty here in SA good back up and fairly priced
