(Another) exhaust question!
asl - 2/5/09 at 08:18 AM
Hi. I know this has been talked about many times so I have spent some time searching through the discussions.
I have an MK Indyblade with a non-repackable exhaust and I spend my time worrying about noise for track days.
I want to buy a new repackable exhaust that will reduce the noise as much as possible.
Can anyone recommend where the best place to buy one from is and which one specifically I should buy?
Thanks all.
eccsmk - 2/5/09 at 08:24 AM
do you have a pic of your exhaust?
i have an early mk exhaust and it just has 4 rivets holding the end cap on.
also mk now sell a lager 6" can designed to keep the noise down on a BEC
HTH
slimtater - 2/5/09 at 08:45 AM
I would contact Martin himself at MK Engineering - he sorted mine out.
Danozeman - 2/5/09 at 10:25 AM
Can you not ut the end of and get a flange welded on so you can rivet the end on? Thus making it repackable?
asl - 2/5/09 at 04:07 PM
Thanks for the reply guys. eccsmk I can't work out how to attach images so will put some pics in my archive cheers.danozeman that may be slightly beyond my capabilities!! thanks anyway
