all set to start!
skinned knuckles - 20/11/09 at 12:01 PM
I have prepared my shed by installing a 30A feed, I have practiced my welding, picked up some box section "scraps" from my local engineering firm (cheers Phil), set up a level and flat work table and drawn out for the layout for the lower chassis members on the table. no turning back now... will leep everyone posted on progress and will update with photos as i go.
all advice and critique welcome as i plan to take my kids out in the completed car and want it as safe as poss
speedyxjs - 20/11/09 at 12:14 PM
It was a long time ago when i was at that stage
Have fun
iank - 20/11/09 at 12:21 PM
Make sure you have a way of putting out minor fires on the build table
Measure twice cut once.
Have a ball
Bluemoon - 20/11/09 at 12:40 PM
Just remember it's not a race, but a fun project.. If it seems to be taking an age, get along to meet fellow builders and cars..
All the best,
Dan
blakep82 - 20/11/09 at 12:49 PM
oooh i remember the excitement of that stage
just remember there will be frustrating and annoying times, but once you resolve the problems and the car gets nearer to being done, it gets even more exciting
speedyxjs - 20/11/09 at 01:40 PM
X2
I called mine a deep breath
Seriousy though, if you dont already have one, get a fire extinguisher and keep it close by. I manager to get one with a mounting bracket that i have now put in the car
iank - 20/11/09 at 01:57 PM
Squeezy bottle full of water is cheaper and less messy than setting off an extinguisher for a bit of smouldering plywood. (not saying you shouldn't have a proper extinguisher to hand - just in case it's not enough!)
skinned knuckles - 20/11/09 at 02:00 PM
Thanks for your encouraging comments fellas, I have already descovered the need for a fire extinguisher its strange how you cant see flames when your welding helmet is on ) thank god Mrs Knuckles happened to walk in with a cuppa and use it to put out the flames making their way up my trouser leg from the frayed bits at the bottom of my jeans. never got a replacment cuppa though, only a week of wee taking from my family and friends. can't figure out how they found out though the wife must have found out about my signature on this forum......
Daddylonglegs - 20/11/09 at 03:12 PM
But just before you cut, measure again!
Good luck
Mr Whippy - 20/11/09 at 03:26 PM
you can't say you've welded unless you've set fire to yourself at least once
Cotton is the safest thing to wear though, I don't wear boiler suites as I've set 3 on fire in the past and they are difficult to get out of quickly
blakep82 - 20/11/09 at 04:07 PM
same goes for the angry grinder
lost count of the times i've set my gentleman vegetables alight with it...
gazza285 - 21/11/09 at 01:26 AM
Buy a decent set of proban overalls, not just a cheap boiler suit.
Anybody who sets themselves on fire with a grinder must be some sort of idiot, anybody who does it more than once needs it taking off them.
cobra427 - 9/12/09 at 10:56 AM
I'm joining you - after 3 years of fightin the council to build a garage - I've given up and im renting one.
But OMG is it a beut...
huge compressor and a pit and a bit laid out as a spray booth
wilkingj - 12/12/09 at 08:10 PM
Hmmm they all say......Measure twice... Cut Once.
Well I say... Think twice about Safety BEFORE doing anything!!!!
The home workshop is a fun place to be and to build your car. However, you dont want to have an accident or injure yourself.
Have some good lighting in the garage.
Paint the walls white to reflect the light onto the car.
Get a whiteboard for making notes and doing quick calculations (I used an old secondary glazing unit whitewashed / emulsioned on the back side).
Get an old radio for something to listen to!
Keep the garage TIDY (to stop you having accidents).
Take your time, and get it right.
Ask questions on here, and THINK everything through BEFORE doing anything.
You should be enjoying the build, I know I did.
There is plenty of help on the forum... so dont worry, just ask away!.
Happy Xmas!
