We're getting a new garage door (not like the ones posted earlier unfortunatelty ) and the bloke has just phoned to say he can do it in 2 - 3
weeks
As im on holiday between 1st - 9th August, this means i have 9 days to get the car in a position that my parents can move it out of the garage
Should get the coilovers this week from alfasudsprint (thanks mate), need to weld on front and rear suspension brackets, order some new bolts for the
front upper bones, torque up pretty much the whole back end and the biggest job, tidy the garage
put it on casters
Originally posted by cd.thomson
put it on casters![]()
what are you doing on here?! go on get a move on!
Originally posted by blakep82
what are you doing on here?!go on get a move on!
Take the engine out, then a parent on either end should be able to carry it out no problem.
Cant, need to get to bed soon, early start in the morning![]()
Couple of old skateboards will do as Castors.
HTH,
James
go and get yourself a supermarket trolley to make a rolling frame.Homebase sell em for a quid.
no a quid buys you 30 trolleys chained together to get them all home safely
if you don't fancy 'buying' some trolleys, just clamp on the suspension points. Far better to spend some time and get it right than rush it now.
If you haven;t got coil overs yet Get a bit of broom handle cut to length and drill holes for the pick up bolts.
Cut some 2x2 to length and put a notch in each end, lift the end of the car and wedge it in then lower to trap it. Oops forgot what engine you're
using, better make it 4x2
