M16 replacement
Mark Allanson - 21/5/10 at 07:42 PM
My RHF caliper has started dragging, and I am not prepared to mess around with seals etc, the M16 is easily powerful enough for me, so what are the alternatives/good sources of replacements
austin man - 21/5/10 at 08:05 PM
big red on ebay can do replacements it is easy to do your own I bought a new set of pistons and seals for around £70. you could always go the hi spec route but will be £200 plus
big_wasa - 21/5/10 at 08:10 PM
Any motor factors will do you refurbs on exchange.
saves on the postage to big-red.
flak monkey - 21/5/10 at 08:17 PM
Motorfactor refurbs will only be about £60-70 a piece exchange.
Even people like halfords usually charge the same as a 'proper' motorfactors for exchange calipers.
40inches - 21/5/10 at 09:25 PM
Don't Wilwood do a direct replacement? Rally Design do recon ones
JoaoCaldeira - 21/5/10 at 09:36 PM
I've got Raceleda R16... brilliant.
I've already used big red in the past - with success
Mark Allanson - 27/5/10 at 08:39 PM
I have just changed both fronts for £66+vat the pair, working great.
Local factor got them within 24h, and a £10 surcharge each.
