Has anyone ever used these to secure coolant hoses before, Self tapped on to chassis then clipped in.
Thoughts??
I need to run heater hoses so this was my thought as I need 30mm clips. Its either these or P clips of course.
I would not, likely to chaff whatever hose is clipped due to vibration...
But if you lined them i.e. put the hose inside a hose it would probably be o.k.
I would not bee keen on tappers, as well but this is personal thing, would rather used rivets (the self tappers will work o.k but don't seal the
tube and can strip as the pitch of the screw is about the same as the wall thickness of the tube...)..
Dan
[Edited on 4/12/13 by Bluemoon]
I've not used them, but its not a milion miles away from the plastic ones that tin-tops use
the only issue I can think of is with them being metal they could eat into the hoses with the vibration, so maybe a little bit of sleeving at the
points where its clipped might be a good idea
the only other option is to use metal pipes for any long runs (solidly fixed) and just use rubber/silicon for the bends
btw - what do you call that kind of clip ? - I needs some for my kitchen...
I would not bee keen on tappers, as well but this is personal thing, would rather used rivets (the self tappers will work o.k but don't seal the tube and can strip as the pitch of the screw is about the same as the wall thickness of the tube...)..
Dan
Its a called a Spring clamp, cheapest place is this site![]()
http://uk.opitec.com/
just search and you get plastic and metal ones as a result in various sizes.
Plastic ones might be o.k (vibration wise)..
Can you get a metal P-clip then steel the rubber lining off that and put it on the clamp you suggested?
How about using a bit of heat shrink tubing on each leg of the spring clip? Would provide the protection you need, and heat shrink is very abrasion resistant.
I made large p clips from a strip of aluminium and some edge trim.
Cut the aluminium to length, bend round something similar size to hose, cut two lengths of edge trim to protct sharp edges. Simple and virtually
"free" as it can be done with offcuts. I made a few to hold hoses in different positions by bending the aluminium differently at the bottom.
Check out in my build diary. LINK
[Edited on 4/12/13 by Sloan85]
Cut the aluminium to length, bend round something similar size to hose, cut two lengths of edge trim to protct sharp edges. Simple and virtually "free" as it can be done with offcuts. I made a few to hold hoses in different positions by bending the aluminium differently at the bottom.
If your looking at securing them for IVA you might want to check with the inspector if they need to be. My inspector was only interested in fuel, cable and brakes. I have 2 clips on the whole of my cooling system - one off the rocker cover to hold a hose away from the cam pulley and another to hold the hose away from the sparkplugs - the rest are all self supporting. I have however covered some bits of hose with extra rubber so they can not chaff if the engine moves/vibrates.
As already said just cover the sharp bits with a couple of layers heat shrink.
Similar clips are used on production car plumbing but only where there is not a lot of relative movement.
You could secure them with a cable tie around the top ears.
Just a bit of trivia.
Originally made by Herbert Terry & Sons, Redditch. (est 1855)
Hence they are know as "Terry Clips"
They can be bought plastic coated nowadays, in fact I have them holding a pump to my road bike frame.
Paul G
So the parts came.
10x L brackets
20x Spring Clamps / Terry Clips
10x P clips
So I took the P clip rubber off and put slits in it and fitted it to the Spring clips.
I then attached it on to the L bracket, You'll notice I have 4. The 2 with rubber hoses on are for the heater pipes and the other 2 (which I will
get more P clip rubber for) are for the aircon pipes. That should neatly hold them on top of the car tunnel.
[Edited on 6/12/13 by killerferret666]
