Hi
I'm looking for a rear disc that will fit over the sierra hub (145mm) diameter with a fairly small offset.
Someone suggested a mk3 escort one and lent me one to try but the ID is only 136 so it won't fit!
Any help appreciated!
Ben
You would normally turn the sierra hub down to allow fitment of the escort front discs.
Plenty of spare meat on them, you just need to find a friendly man with a lathe.
Al.
Might be worth adding your location to your profile, maybe someone local will step forward.
Originally posted by benners05
Hi
Ben
can't confirm the inside diameter right now, but how about sierra discs for your sierra hubs ?
Well that's a novel idea!!
I think the only issue with the sierra ones is they don't suit all the aftermarket calipers / caliper mounts
Just jumped on the lathe after work. All fits now!
Ben
