Took my top steering UJ to bits today due to some wear. Thought it was a standard 15mm size which should be easy to obtain but the holes are 14.8mm.
Ford say they can't get them. Anyone any idea of the equivalent sizes or a part number.
It's the joint that is nearest the triangular end of the column. Thought I'd try here before I splash out on a 15mm reamer that I'll
never use again.
have you tried GBS, i got one from them previously but not sure of size. was standard sieera bits
Tried everywhere. Went to CPS drivelink who did my prop and they've reamed it and supplied me a joint for £20.
