buying measuring instruments
locoboy - 8/11/06 at 09:44 PM
Im after a dial test indicator or dial indicator whatever you wish to call them.
preferable with a magnetic base but not essential.
Where is a good place to buy a reasonable quality one. I would rather buy a second hand 'good' quality one for the same money as a new 'lesses quality' item.
also after a set of vernier calipers too!
flak monkey - 8/11/06 at 09:51 PM
Mitutoyo ones are good, as are mercer ones. For new stuff have a look here:
Linky
If you can, get an 0.002mm one, or 0.0001".
As for second hand, if you want a good one dont bother...
andyd - 8/11/06 at 10:23 PM
I just got a radius gauge and digital vernier from http://www.tooled-up.com/
They do a wide range to suit whatever size pocket you have.
crbrlfrost - 10/11/06 at 01:12 AM
Just a random note, a dial indicator and a dial test indicator are not the same tool. A dial indicator has a straight travel and a relatively long range (.5-2''+ depending on model). A Dial test indicator has a movement of an arc and usually only has a range of .03-.06''. These are usually used for set-up and very fine measurements in the machining industry. You want a dial indicator, by far the more useful one for building engines. Cheers!
NS Dev - 10/11/06 at 09:01 AM
thought they were both called either name? There are many different types of dial indicator (test or otherwise) with levers and goodness knows what attached to them!
Syd Bridge - 10/11/06 at 09:05 AM
You're right Nat. Difference is semantics, usual source.
Differring terminology either side of the atlantic, and sometimes coasts!
Syd.
02GF74 - 10/11/06 at 09:21 AM
I got a dial guage from axminster tools
[url=http://www.axminster.co.uk/product.asp?pf_id=21170&name=dial+guage&user_search=1&sfile=1&jump=0]
at £ 13 was cheaper then MM; no problems in the 3 times I used it
accurate enough to find TDC on a V8.
Mark Allanson - 10/11/06 at 07:46 PM
Over here commonly called a 'clock' and a 'finger guage'
