anyone run virtulisation on their PC?
Dangle_kt - 12/12/08 at 11:31 PM
Reading up on virtulisation (we are looking to go virtual on our blade servers at work next year, and I want to shock my IT team!)
Planning on using virtual box on my home PC, and throwing a copy of fedora on it, so I can try a load of open source stuff. Always fancied trying linux, and fedora seems up there with the most intuitive to a windows user.
Any comments or thoughts welcome.
[Edited on 12/12/08 by Dangle_kt]
cloudy - 12/12/08 at 11:49 PM
I recently specced and installed a 3 host VMware ESXi cluster (Each Dual Quad core 3Ghz / 16GB RAM) backed by two lefthand networks 4TB iSCSI sans, runs 20 live servers without breaking a sweat, and is practically bulletproof
Servers float around the cluster, migrating still live, the storage self replicates and backs up and there isn't a single link that isn't redundant
VM is the way to go!
Dangle_kt - 13/12/08 at 12:03 AM
Do you have to purchase 20 windows server 20xx licences to operate like that?
cloudy - 13/12/08 at 12:07 AM
Yes
Dangle_kt - 13/12/08 at 12:14 AM
yeah thats what is putting off the ceo, not cheap.
If you have 5 host servers, could you run 5 virtual servers and have them so they float around in case one of host servers dies?
Would the 5 host servers need licences too?
Thereby making 10 in total?
I think that is what you said earlier...
[Edited on 13/12/08 by Dangle_kt]
James - 13/12/08 at 12:18 AM
First started playing with VMWare and Virtual PC about 8 years ago.
IIRC VMWare was better with Linux and other non-windows virtual machines and Virtual PC better for Windows based stuff.
On a Win 2000 PC I had simultaneously NT, Win2000 Server and a customised Linux build all running at once.
Pointless to me at the time... but fun all the same!
James
cloudy - 13/12/08 at 12:36 AM
ESXi itself is now free, you pay for the management utilities, vMotion, Consolidated backup and most importantly the infrastructure server which manages the whole kaboodle
We are looking to do that exact thing to aid portability and reliability, running a 1:1 ratio by just adding the layer of ESXi behind the scenes, no extra licenses would be required, allthough you loose a lot of the benefits associated with VM server consolidation....
In your example just 5 licenses would be required, ESX the hypervisor runs in a tiny customised linux OS, you don't need windows to actually provide the host
James
[Edited on 13/12/08 by cloudy]
SixedUp - 13/12/08 at 02:29 AM
For what its worth, I run Ubuntu 8.10 as my main host operating system, and then use virtual box to provide a series of guest operating systems, as I need them. Works just fine, even on a laptop. However, to virtualise Windows operating systems you need a processor that has virtualisation extensions (VT-x or AMD-v) and a reasonable amount of memory - I have 2GB.
Also, unless you really have a burning need to use Fedora, I'd really suggest Ubuntu as a better first Linux. Its easier to manage than Fedora, and has a much larger community (ie more people to help you!)
vinny1275 - 13/12/08 at 09:41 AM
For Windows virtual licensing, look at the licensing for different versions of 2008 server (which is really good btw). In 2003 if you used the enterprise edition as the host OS, it gave you a number of licences to use for the virtual guests as well - can't remember how many or if it was worth it, but worth a look.
If you use a regular software supplier, give them a shout and ask their advice, MS licenses are some branch of magic!
HTH
Vince
cd.thomson - 13/12/08 at 10:05 AM
Hi there, don't use virtualisation myself, but I'm definitely a bit of a linux geek. Red Hat/Fedora platforms used to be the only real windows killers as far as usability goes but I think ever since the "Fiesty Fawn" update of Ubuntu this has been blown out of the water.
Very userfriendly, based on GNOME, fully customisable and nonrestrictive, huge support/development community. All means you cant really go wrong.
Have a look at Ubuntu JeOS, its designed for virtual applications specifically, although tbh I am completely unaware of what its capable of when compared to what you need it to do.
yellow melos - 13/12/08 at 10:13 AM
you will have to be carefull of what Network cards you use as the over head of managing the packets to the different virtual server can cause slowdowns, on a test envoroment it doesn't matter but in live production it will.
On the licensing front, you can use a license on one machine... so you can install it as many times as you like.... so if you have 1 machine running windows 2003 server... you can VMware that license 20 times if you like as it's on the same machine. but if you installing Linux then there are no licensing issues anyway.
britishtrident - 13/12/08 at 11:05 AM
I run Windows as a virtual machine on Mint Linux host using InnoTec VirtualBox --- They do VirtualBox for Windows but I wouldn't fancy doing it the other way round.
With VirtualBox the virtual machine dosen't have to share the same network card as the host operating system --- I think it should be the same for VMWare.
I have also run various Linux version in a virtual box even tried running a virtual machine within the virtual machine.
The main problem I encountered was setting up the graphics card & resolution for the virtual machine.
Forgot to add
http://www.virtualbox.org/wiki/VirtualBox
http://www.linuxmint.com/
[Edited on 13/12/08 by britishtrident] Rescued attachment virtualbox.jpg
britishtrident - 13/12/08 at 11:22 AM
I will also add avoid Fedora. Fedora is very seductive but new releaes tend to be buggy as hell and the buggs don't get fixed --- look on it as an alpha version of of a future Red Hat release.
Fedora is not Debian based and it is best to avoid any Linux distribution that dosen't use the "Debian way" of software distribution.
Unbuntu is much better but it is a general purpose release at new versions tend to a more than a little buggy. Mint is basically a sorted more user friendly Unbuntu and it has a fully sorted VirtualBox package ready to download and install using Mint install.
So best advice is download and install Mint on an old system box or hard disk play withit for a couple of weeks then install VirtualBox or VMware on it.
nstrug - 13/12/08 at 05:18 PM
Confession: I work for Red Hat.
Virtualisation is hugely important to us at the moment - in RHEL we ship xen, and in Fedora 10 we are shipping kvm. However, both of these hypervisors are 'hidden' by an abstraction layer, libvirt, so it doesn't really matter what the underlying technology is - in fact we can live migrate a virtual machine from a xen to kvm hypervisor with no downtime.
I strongly recommend you look at Fedora 10. I personally run it on my laptop (Lenovo x300) and the virtualisation is very useful for spinning up virtual machines with all our supported operating systems on (RHEL2.1, 3, 4, 5...), reproducing customer issues etc. I _should_ run RHEL5 on my laptop, to toe the company line, but I like all the spangly desktop effects that we don't ship with RHEL yet
The only bits missing from Fedora that you might find in Ubuntu are various legally encumbered codecs (mp3, DivX etc.) Unfortunately we can't legally ship these, however they are available in RPM format from various 3rd party repositories.
If you have any questions, or want some Fedora DVDs, or are interested in RHEL, please don't hesitate to PM me, or e-mail nstrug@redhat.com.
Nick
