hi all ,
need to fit some carbon front archs,
what do people do to stop them removing themselfs?
before car had about a ton of silicone holding them on but not sure what type etc as i did not put them on, am i best of bolting them on aswell and
sealer or will that crack the carbon and look crap
Stika flex/ tiger seal / pu adhesive , double up on latex gloves when using it takes 3 or 4 days to get off your skin and i have 1 bolt on each bracket just on the inner edge just for good measure
Make sure you key both surfaces before applying the silkaflex, some people also bolt them as a precaution the next time I fit arches I will also be fixing a strip of ally to thr underside with blobs of silkaflex to prevent stone damage. Wish I had done it to the back wings I wouldnt have the cracks I have now
I have mine secured with Evostick "Sticks like S**t", another PU adhesive. I allowed this to set for a couple of days, then cleaned up the PU around the brackets and then put a couple of layers of CSM over the whole lot, much neater than having bolts sticking through the gaurds, IMHO. HTH Ray
Hi,
I use a Loctite product called 9466 x 50ml .
Its like a two part Araldite , but it self mixes in a special nozzel, but you get a few nozzels with the adhesive.
Used this to bond the front cycle wings onto the stays on my race car, and they never budged.
Hope this helps.
Regards Chris.
Need to buy wing stays & wings for cortina hubs 195 tyres wheres best place
