battery acid! / alternator / fuel pump- help!!
les - 1/5/08 at 02:18 PM
dear all,
had massive problems today after a quick run out.
noticed a squeal from the alternator belt, nothing major so decided to sort it when i got home. this got louder until i stopped,
on looking under the bonnet I found the battery was red hot and had spilled acid all over the engine bay / scuttle, the alternator was also hot ( although that could just be the engine bay) - the ran to germany last year with no problems, the only thing I have changed is to add a second fuel pump in a swirl tank system to stop fuel starvation at the track, I wired this by running a thick wire direct to the positive terminal on the battery, with a switch on the dash and inline fuse, then earthed at the fuel pump to the chassis.
seems to much of a coincidence?!! could this have somehow caused the battery to get hot and spill over? then the alternator to stiffen up with the added load, causing the belt to slip?
help!!!
les
Mr Whippy - 1/5/08 at 02:24 PM
don't think it's to do with the pump, sounds more like the alternator is going nuts and overcharging. Check the voltage across the battery should be not much more than 14v, rev the engine, I suspect the voltage will climb quite high.
[Edited on 1/5/08 by Mr Whippy]
02GF74 - 1/5/08 at 02:40 PM
hmmm - I wonder if there is some fault with the wiring for the second fuel pump or the pump itself so that it increases load on the battery;
not sure if that will boil it but certainly would put a strain on it and the alternator.
pewe - 1/5/08 at 03:10 PM
Les, and now the bad news........ if you haven't already done so you need to urgently wash everything (and I do mean everything) with at least plain water or better a solution of bicarbonate of soda - as strong as you like to neutralise the battery acid.
Do it a few times to make sure it's all gone.
Be aware that battery acid is very, very corrosive.
Also avoid any contact with skin, eyes and don't inhale any fumes.
As a lad I left a loose battery in a customer's car and the acid when spilled quickly ate through the carpet and attacked the floor in no time.
Sorry to be the bearer of bad news.
Pewe
In fact agree with miniciti .... flog it quick. The on-going problem is that if you don't kill every last drop each time it gets damp it will re-activate and eat into whatever it's sitting on!!
[Edited on 1/5/08 by pewe]
minitici - 1/5/08 at 03:16 PM
As above - treat the spilled acid quick - or sell the car even quicker before it dissolves.
les - 1/5/08 at 04:08 PM
hi thanks guys,
What i have done so far is soak up all the acid and throw away the cloths, then disconnected and removed the battery (and thrashed it with a branch for damaging my car!!!) then washed out the bonnet / inside the car with a hosepipe. after thinking further I tghen washed out the underneath of the dahsboard where the wiring is as some had got through- thought washing it, although bad, was not as bad as leaving the acid- did that twice. as you say, everything iti touched is now either a funny colour or melting.
dont really know where to start as electrics are my weak point- new battery as a start then check voltage across it? anyone know how I should change the pump wiring?
les
- every time i drive its a different problem.......
Paul TigerB6 - 1/5/08 at 04:29 PM
As Mr W suggests, is sounds very strongly like the voltage regulator in your alternator has packed up and is seriously overcharging your battery.
The regulator limits the voltage to about 14V so if you put a voltmeter across the battery terminals and then rev the engine you will probably see much higher than 14V if the regulator has died.
Bluemoon - 1/5/08 at 04:29 PM
Reminds me of why I should look for a plastic battery box in the scrap yard..
Dan
RazMan - 1/5/08 at 04:39 PM
As already said, you will need to nutralise the acid with bicarb or it will continue to munch away at everything
MikeRJ - 1/5/08 at 05:47 PM
Almost 100% certainly the voltage regulator. This would also put a high physical load on the drive belt (as the alternator is pushing a lot of current into the battery), hence the squealing belt.
Battery will probably also be knackered, if they get hot the plates tend to distort.
les - 5/5/08 at 01:54 PM
thanks guys,
ill try to test it and report back- alternators seem to be a real problem on these cars- i have only had this one a year and it was brand new,
anyone know why they fail so often?
les
Paul TigerB6 - 5/5/08 at 02:02 PM
Depends on your setup but i fried 3 Lucas LRA101 alternators on my old Zetec car as the Tiger supplied pulley was too small. This was allowing the alternator to over-rev and fry basically. Solved this by fitting a small Nippondenso alternator with a larger pulley. Other problems could be caused by high underbonnet temperatures, especially if the alternator is near the exhaust.
