I took my tintop into Halfords to get the toe sorted, so they put those laser thingies on the front wheels, and the gauges on the back. After much
screaming and shouting at the seized track rods, they finally got the front wheels to zero, with both rears showing 6 degrees. Apparently that 12
degrees between rears is because the rear axle is damaged.
However, what I didn't understand is how they are able to measure the rears? There's a laser on the fronts that measure the difference
between the two, and then lasers from the front devices to the rears. But unless my GCSE maths is failing me, I didn't understand how a laser
fixed to the front could tell them the toe of the rears. From what I could see, even if the rears were adjustable for toe, the gauge wouldn't
actually show a different reading as the wheel moved. And the rear reading could be upset by anything that would push the wheel out, such as a spacer
or the wheels offset. Or even a difference in track from front to rear.
Are they just measuring the fronts in relation to the rears, or are they actually able to measure rear toe?
[Edited on 22/9/12 by Slimy38]
Halfords.................................
A tool is only as good as the guy using it, did they do all the basic checks first; Ball joints, TREs, Bushes, Springs, Wheel and Tyre run out
12 degrees is an awful lot of toe so much it I would think even be noticeable just looking at the car and it would certainly effects on
the handling, what vehicle is it ?
you should put the front gauges on the rears 1st and set them up then move gauges to the front and set them up
Smoke and mirrors
Did they measure 12 degrees which would be extreme, or 12 Minutes (0.2degrees) which might be about what you might expect?
As BT says, it's all done with mirrors.
They showed me the scale at the end, the lasers pointed to '6' on both sides. I thought I remembered him saying degrees, but 6 minutes would actually be more likely and within tolerance. And the way it drives would also suggest the same.
this is how i do it but i put the front end on axle stands . works evry time and im 100% happy with it
http://www.youtube.com/watch?v=0ziovI1651o
Originally posted by thunderace
this is how i do it but i put the front end on axle stands . works evry time and im 100% happy with it![]()
im assuming that they use a similar system to my supertracker which is the most popular kit .the rear flags have nothing to do with the toe reading
at the front it merely shows that the toe is equally spread on both sides with the steering wheel straight .
the normal procedure is to clamp the wheel in the straight ahead position them any adjustment must be equally done to keep the wheel straight . when
the rear flags show the same figure and the toe is right at the front it means the wheel will be straight as you drive ,the figure means nothing as a
car with slightly wider track at the rear will give a different reading but for the majority of cars running a touch of toe in or out the flags will
read between 5-9 .if the front was 100% parallel the flags would be close to zero and say 2mm of toe in over the 5-6ft between front and rear wheels
would show around 5 .
the front measuring system gives a numerical value rather then degrees and minutes and the usual reading are oppsite each other i.e one side says toe
in 5 the other toe out 5 which cancel each other out so in fact they are parallel . if you have one side saying +5 the othe side says -6 and the rear
flags are both reading the same you have toe in of 1 if you get my drift
Yep, having gone on the supertracker website it looked like they were using the laser wheel aligner. Thanks for the explanation, so it sounds like
they've done a 2 wheel alignment and the rear flags were just there to make sure that the front wheels were straight ahead at the same time as
the steering wheel.
I guess I'll have to find a more competent garage to determine whether the rear wheels are actually out of alignment.
