I tried asking this on mx5nutz but wondered if anyone had a clearer answer
Could anyone help with coolant temp sensor wiring?
I have a mk2 1.8 engine with a coolant reroute done and I'm using megasquirt 2 extra. The sensor is the triangle shape 3 pin one.
Wires are:
Violet/white
black/red
red/purple
it then goes into the fuel injector harness plug and changes to.
blue/white
black/blue
black/blue
i could do with knowing which one is signal which one is gauge and what is the other for, i thought it can't be ground as the sensor is grounded
in the head.
http://www.mellens.net/mazda/index.html
should all be on there
I've already looked at that....but obviously not close enough
Violet/white are to the gauge, one of the other colours must be to a warning light and other is to megasquirt. I think if i do a continuity test from
one of these to the actual sensor to find which one is sensor ground the other must be to megasquirt.
paul
sorry,cant help any more......i have a MK 1
