Hi I am searching for 36x 3mmx3.5mm loose roller bearings searched net to no avail help required from the collective they are for a connecting rod on a cutting machine many thanks chicade
Try Brammer.
Or try
http://www.eabs.co.uk/
Very helpful and if they exist, they should be able to get you one!
Unfortunately some manufacturers (Yamaha) make their own silly sized roller bearings which are impossible to get hold of without going directly to
them!
thats an odd size have you got the right sizes you need the id/od and with so would it be 36 x 33
i use vxb.com they list just about every bearing made and bearink-kink.co.uk these also do seals at great prices
[Edited on 31/5/13 by rick1962uk]
I think he wants 36 off 3mm dia x 3.5mm long cylindrical rollers.
