BMW K100 throttle bodies - suitable?
luke - 2/1/10 at 09:47 PM
hey all,
Mate of mine has a K100 for a mini project and has the TB's spare, they have a 36 mm diameter and look easy to respace.
would they be suitable for a stock 1800 zetec? or would i find them too restrictive?
Luke
marcjagman - 2/1/10 at 10:12 PM
If you can mount them on a suitable manifold and jet correctly, can't see any ptoblems
will121 - 2/1/10 at 11:13 PM
they would do the job and do look easy to respace, also looking at pictures they dont have integral injectors which is not a problem on a zetec as you can use a 1800/1600 standard injector sandwich plate, ive done a couple previously using gsxr throttle bodies some info here
zetec manifold/throttle bodies
[Edited on 2/1/10 by will121]
Numb nuts - 3/1/10 at 04:33 PM
Nice one
I am using Yamaha R6 throttle bodies on a similar set up on a 1.8 Zetec they run well.
Am now fitting them to a modified 2.0 Zetec but am not happy with the angle of throttle bodies on the manifold.
Do you...or anyone else for that matter, know where to get a blank plate for the manifold to sandwich plate from, so I can make a new one?
Steve (also in Norwich)
big-vee-twin - 3/1/10 at 04:36 PM
You could use an ST170 inlet manifold, got mine from ebay.
