chips do they work
davev8app - 3/10/13 at 10:36 AM
Just won a Vauxhall 2.0 8v Carlton Engine And Gearbox for my below £1000 total (including the dutton) re engineer/re build of a dutton s2 roiling shell i have (will be some photos of the build on here soon)
so has some one on here had experience with a chip like in the link below ..
OPEL VAUXHALL Astra 2.0 8V C20NE chip 131HP Calibra Vectra Cavalier Kadett GSi
loggyboy - 3/10/13 at 10:37 AM
At that price i supsect thats a very expensive 'resistor' mod.
dave_424 - 3/10/13 at 10:43 AM
They usually mess with sensor readings, on the diesels they mess with either the fuel temperature reading tricking the ECU into adding more fuel or messing with the fuel pressure reading, tricking the ECU into bumping up the fuel pressure.
Dave
mark chandler - 3/10/13 at 11:11 AM
If you eat enough of them you stop being hungry, so yes
davev8app - 3/10/13 at 11:30 AM
Tell me abut the "cheap" resister mod ...i am guessing it just to lie to the ECU......this is the 1st time i mess with ecu etc so a bit of a learning carve in making it all work
..if it hassle me to much it will get a belt driven dizzy with points and some SU carbs
davev8app - 3/10/13 at 11:32 AM
my waistline already hampers my 0-60 time
loggyboy - 3/10/13 at 11:48 AM
These are the cheap ones
+15BHP Power Mod/Chip Peugeot 106 107 206 207 208 307 308 3008 408 508 5008 RCZ
STOP then. Dont mess about with ECU mods unless you know what your doing.
The above resistor mods are a waste of time, if it was that simple to extract more power, the manufacturers would do it.
Performance has a cost for a reason.
britishtrident - 3/10/13 at 12:15 PM
The resistor trick worked to an extent on early ecu controlled injection systems but modern engine management system do a sanity check of the sensors at start-up by all comparing the sensor values, if the sensor reading doesn’t make sense it will simply be ignored and a default value used.
davev8app - 3/10/13 at 12:20 PM
I not mean its the 1st time i mess with ECU mods, as mod the ECU.. its the 1st time i do a engine transplant with a ECU etc
any mods will be looked at after it running well in stranded form
