Poll: How many Luego's out there [View Results]
Viento on the road
Viento being built
Velocity on the road
Velocity being built
Locost on the road
Locost being built
Thinking about buying a Luego
<<  1    2  >>
Author: Subject: How many Luego's out there
rickys2000
posted on 17/10/08 at 09:18 PM Reply With Quote
Viento with s2000 nearly ready for SVA in st albans
perci
posted on 18/10/08 at 03:30 PM Reply With Quote
viento v8 on the road northants!
andybod
posted on 18/10/08 at 07:42 PM Reply With Quote
velocity xt still half built four years later must get round to doing something on it not put a spanner on it for 2 years
Scotty
posted on 19/10/08 at 09:20 AM Reply With Quote
hi mate
was the same myself but FINALLY! got there
keep at it, suddenly it will all start coming together again!
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
jollygreengiant
posted on 19/10/08 at 10:16 AM Reply With Quote
I agree with the last post, don't give up. go and see her, talk to her gently and kindly, she will forgive you. Then pick up a spanner and crack on. It will be worth it. Mine spent nearly 2 years in the beginning doing nothing, before I got on it now I am looking at SVA sometime around January(ish). I can't wait. My biggest problem is finding time, I normally oly manage a couple of hour at the weekend, but it IS getting there.
edit bit - ......
I'm sure that if you would like a few of us could turn up one Saturday/Sunday, give you a run out in one and then get in the garage and give you a restarting hand. Unfortunately I wouldn't be able to turn up in mine till after I've got it SVA'd but I'm sure we could sort something out for you.
[Edited on 19/10/08 by jollygreengiant]
craig_007
posted on 19/10/08 at 02:15 PM Reply With Quote
Mines is a locost using the velocity body panels,Does this count ??
I'm up in Scotland.
jollygreengiant
posted on 19/10/08 at 02:28 PM Reply With Quote
Originally posted by craig_007
I'm up in Scotland.
If nothing else it qualifies you for the Luego Owners club.
repper
posted on 19/10/08 at 06:44 PM Reply With Quote
V8 viento being slowy built in york
iam on with the fuel system at the mo[img]http://locostbuilders.co.uk/upload/a823609-P020608_12.59[01].jpg[/img]
tomgregory2000
posted on 19/10/08 at 10:11 PM Reply With Quote
thats just porn!!!!!!!!!!!
Brian S
posted on 26/10/08 at 10:18 PM Reply With Quote
I have the Blue Viento ex demo. I'm in West Sussex.
Brian
posted on 27/10/08 at 07:37 PM Reply With Quote
Welcome to the forum and the Luego owners clubs . (if you have a Luego it's compulsory) Mel
jollygreengiant
posted on 28/10/08 at 11:21 AM Reply With Quote
Brian
Welcome Brian.
Ahhhh good old West Sussex. I was born down there. 220 yards from the sea in Bognor Regis. (when you are 12 years old you don't have much choice about where you live, which is why I am here now.)
richwill
posted on 28/10/08 at 11:29 AM Reply With Quote
Getting towards finishing mine. Have the front lights to finish wiring and then the dash to sort out. I could do with going out for a shakedown but will need to borrow a trailer for that. I hope to finish in the new year. I will get to post some photos one day soon.
wilkingj
posted on 28/10/08 at 12:41 PM Reply With Quote
Brian
Welcome Brian...
In my Picture archive (on here) I have a lot of photos of your car, which I took to help me build mine.
They are about 4+ years old, so you may want a look to see if anything has been changed.
Best Regards
Geoff
http://www.v8viento.co.uk
simonk
posted on 28/10/08 at 01:23 PM Reply With Quote
Hi Repper
Don't go too much further without the diff in place - it leaves very little room for the plumbing. Also you may find that you can't fit the diff with the bottom wishbones in as it is difficult to get the bottom long bolt in place as you need the space where the forward bush of the bottom wishbone is. I ended up running the fuel hardline through a pipe gland drilled through the diff mounting plate, and had to break down the offside corner to get the diff in place.
Simon
jollygreengiant
posted on 28/10/08 at 06:06 PM Reply With Quote
Originally posted by simonk
Hi Repper
Simon
The trick with the long bolt is not to use it. I used 2 short bolts and modified the heads so that the bolts fitted from the middle of the diff outward and the heads were held by the channel in which they sit. The nuts were then fitted from the out side.
If that makes sense. I would put up a photo, but I haven't got any.
chris_smith
posted on 3/11/08 at 01:02 PM Reply With Quote
my locost stuart taylor chassis with bits from all over, will have a luego wiring loom does that count
Scotty
posted on 6/11/08 at 07:46 AM Reply With Quote
can i change my voting as
(notice dramatic pause .......)
PASSED SVA Yesterday!!
hurrah!
<<  1    2  >>
