wydraz
posted on 12/12/08 at 11:58 AM |
Team Dynamics Pro Race 1.2's
The supplier mumbled for a while when I answered the 'what car are the wheels for' question, so as I have no confidence in them supplying
the correct wheels, will these fit my Indy?
Ford 4 stud fitment.
195/50/15 tyres
15" wheels, but which offset?
From the Team Dynamics website the following 15" variants are available:
7.0 x 15 e15 / 23 / 25 / 30
7.0 x 15 e35 / 40 / 45
I am thinking probably the 7.0 x 15 with an et35 offset is right to fit nicely in the Indy arches without rubbing?
Thanks.
[Edited on 12/12/08 by wydraz]
PAUL FISHER
posted on 12/12/08 at 01:08 PM |
Your better off fitting the ET40 in my opinion,the ET 35 will fit,but only just clear the arch,and depending which tyres your fitting can rub the arch
when hard cornering,best with the ET40 will set the wheel a additional 5mm inside the arch
wydraz
posted on 12/12/08 at 02:46 PM |
Thanks Paul, are those Pro Race 1.2's et40 15" on the white Indy in your pic gallery? looks good!
mackei23b
posted on 12/12/08 at 02:47 PM |
I think mine are:
15 x 7 x ET38
Ian
PAUL FISHER
posted on 12/12/08 at 04:52 PM |
Yes they are,fitted with 205 50 15,although another option worth considering is MK now can supply 2" wider rear arches,this now opens up alot
wider range of wheels that previously could not be fitted to the Indy,because you had to stick to a limited number of sierra base wheels around the
ET38 offset,revolutions and minilites for example are usually only available in low offsets,but with the wider arch,can now be used![](/images//smilies/cool.gif)
wydraz
posted on 12/12/08 at 07:51 PM |
I saw a car for sale on pistonheads which had these wheels on and the owner had managed to colour code the recessed 'Team Dynamics
Motorsport' text on the outside front of the rim to the same colour as his car.....any suggestions how this could be done? My car is black and
orange and I think it'd look great to have the orange lettering on the black wheels......![](/images//smilies/wink.gif)
Kriss
posted on 12/12/08 at 08:45 PM |
probably best simply using a tin of chosen pait and a stemmed brush and literaly fill the recess i guess. would be way too hard to mask off etc
wydraz
posted on 14/12/08 at 10:06 AM |
What tyre pressures do we all run? Is it dependant on tyre?
Someone told me 18psi all round on my 195/50/15's
