Hi, i,m not an electrician but IMO i don,t think it is the regulator, if it was up the swanny it would more than likely not allow power to the lights
at all, i admit i maybe wrong but i think problem is elsewhere,
such as..... is there something else getting current all the time that maybe shouldn,t be?
i,m speaking from a similar prob i had on my honda vfr, similar electrics, i traced it to a short direct to the frame, so was losing the volts/amps (
whatever the flow is called) prior to reaching the rectifier/regulator. once located the prob & fixed the short all was well again,
its a long shot but maybe something in it.
hth.
cheers
andy
