New Topic New Reply
Author: Subject: Which oil in an 893 blade?
asl
posted on 26/4/09 at 09:41 AM Reply With Quote
Hi. Just going to change the oil in my blade. Which oil and how much does it take? (893 blade) Thanks
slimtater
posted on 26/4/09 at 10:01 AM Reply With Quote
Been discussed a lot - might be worth a search?
I put Castrol 10/40 fully synthetic (Racing) motorbike oil in and I started to get clutch slip. I have changed back to Castrol 10/40 semi synthetic (GPS) and this seems a popular choice - 28.99 from Halfords.
If you search, there have been similar clutch problems when people have used fully synthetic if it previously had semi.
Added:
If your is a 1994 893 (RRR) like mine, I think it is 3.5l without filter change and 3.6l with - only did mine yesterday as well!
There is a good post from AB about the filling process - you need to run a bit extra.
http://www.locostbuilders.co.uk/viewthread.php?tid=95037
[Edited on 26/4/09 by slimtater]
http://www.picturetrail.com/sfx/album/view/19919222
ReMan
posted on 26/4/09 at 10:02 AM Reply With Quote
About 4l of Halfords Semi-synth think it's 10-40 £20
gingerprince
posted on 26/4/09 at 10:25 AM Reply With Quote
I use Castrol GPS semi too. Lovely and red
Kev99
posted on 26/4/09 at 10:26 AM Reply With Quote
Castrol 10/40 semi synthetic (GPS) Thats what i use
ReMan
posted on 26/4/09 at 11:37 AM Reply With Quote
Interesting post you refer to by Andy Bates.
it does not mention baffeled sump or not either. So I don't know wheter that was helped.
I overfill by a little, hence the 4L estimate, but be careful not to over-overfill else it starts the clutch slipping as well, you ask me
slimtater
posted on 26/4/09 at 11:44 AM Reply With Quote
I followed it when I last changed the oil and ended up with clutch slip after about 200 miles. I think it was more likely down to using synthetic. I will let you know if I make it to Stoneleigh as it is likely to be the first drive after new clutch plates/steels/springs plus a change back to semi. Thats if I get an exhaust sorted!
hobbsy
posted on 26/4/09 at 01:33 PM Reply With Quote
Another vote for Castrol GPS (semi) as well - albeit in an R1 (no real reason why it would want different oil TBH).
I did run fully synth before but Andy Bates recommended GPS as its what he runs in all the RGB cars he looks after.
Plus I shared his concern that some of the fully synth oils seem to get VERY thin when hot and this can't help oil surge in a BEC
asl
posted on 26/4/09 at 02:15 PM Reply With Quote
Thanks guys!!
Guinness
posted on 26/4/09 at 05:07 PM Reply With Quote
I used to use the Castrol GPS semi skimmed in mine. Lovely smell and red colour.
Now I have increased the frequency of the changes I've started using the standard Halfords own brand 40/10 Semi.
Mike
ReMan
posted on 26/4/09 at 09:04 PM Reply With Quote
Mike
Just as I mentioned I don't think I need to throw the most expensive oils t a 15 year old engine thats loosened up by %0000 miles , hence Hafrauds finest
New Topic New Reply
