Author: Subject: Any alternative to zetec water rail??
cliftyhanger
posted on 27/4/09 at 10:42 AM Reply With Quote
When I build my next zetec powered spitfire (having rolled the last one) I would prefer to NOT use the raceline type water rail. There is not enough spce for the std thermo housing at the rear, so is there any alternative? Ideally something that just gives me a 32mm outlet sort of like a cut-off water rail.
Is anybody fabricating this sort of stuff?
TIA
Clive
posted on 27/4/09 at 11:07 AM Reply With Quote
Some zetecs have an elbow there instead of the housing, still sticks out a bit but not as much. No idea what car tho sorry.
Took a similar outlet off a zetec SE engine in a scrappy once, it had the thermostat behind it, nice and neat, again don't know if it will fit the bigger zetec.
Saw a solution in one of the ford mags, possibly ClassicFord, basically a milled block with a water way that turned the outlet 180 to exit facing forwards above the exhaust.
There are solutions if you look hard enough
Krismc
posted on 27/4/09 at 07:37 PM Reply With Quote
He can have my water rail cant he steve??
Ive got a blistered foot to prove how good it is.
posted on 27/4/09 at 07:48 PM Reply With Quote
I'd go back to the standard oem unit if I was you Kris.
mattf
posted on 28/4/09 at 09:17 AM Reply With Quote
Clive, you could try Retro ford. They can supply parts for fitting Zetec's into loads of different old Ford's and so they might have what you are looking for.
