Author: Subject: Laptop Power
omega 24 v6
posted on 3/5/09 at 04:06 PM Reply With Quote
Laptop Power
I have an old toshiba satellite that I use for tuning megasquirt. The battery is pretty fubared and I wondered the following
Given that the output of the adapter/charger/mains cable is 15 volts and 3 amps do the collective brains on here think that it would work at say 14 voltsdc i.e when the car is being charged??
I know I could fit up an invertor but I could do it this way much cheaper and with less cables flailing about using bit and bobs I have lying around at work.
So lets discuss
[Edited on 3/5/09 by omega 24 v6]
r1_pete
posted on 3/5/09 at 04:16 PM Reply With Quote
I run an old IBM T21 thinkpad straight off the car battery no problem running or not.
fov
posted on 3/5/09 at 06:58 PM Reply With Quote
Yep, the only issue could be it may feck the battery. So no issue at all in this case...
