bazz81
posted on 29/5/09 at 07:42 PM |
MK Zx-12 engine coolant is hot!!!
A couple of days i've serous problems with the cooling, I read the topics to make some extra hole in the boot to get the heat out, but even
without a hood the coolant is too hot, (zx12 clocks temp. blinking) even with the fan on, is isnt capable te cool down the coolant fluid. Maybe
thermostat? or airlocks?? waterpump?? On the top of the rad its marked 'nissan' so i think its a nissan micra rad??? Please help
[Edited on 29/5/09 by bazz81]
MakeEverything
posted on 29/5/09 at 07:45 PM |
Have you checked the water pump is working correctly?
Kindest Regards,
Richard.
bazz81
posted on 29/5/09 at 07:49 PM |
No, how can i check it; if its working properly?
MakeEverything
posted on 29/5/09 at 07:53 PM |
take it off and check it. I dont know bike engines that well, so i dont know how possible this is. Youre looking for its ability to turn freely, and
for scale on the impeller.
Kindest Regards,
Richard.
Andy W
posted on 29/5/09 at 08:08 PM |
what sort of mesh do you have the nose, you maybe suprised at how restrictive the mesh can be even with large holes in it. (I know it got me, when I
was convinced I had a problem elsewhere)
omega0684
posted on 29/5/09 at 08:19 PM |
1)how big is your rad?
2)could i it be that the rad is too small?
3)is the rad right up front in the nose cone or further back in the engine bay?
4)check the thermastat is working properly
5)check water pump is working properly,
6)check for blockages by flushing out the coolant system
7)is the header cap presurising correctly
bazz81
posted on 29/5/09 at 08:49 PM |
1) radiator is a nissan micra one (possibly)
2) don't think so, car was built ans sva'd in 2002
3)in front of the nose cone
4)how can i check the working of the thermostat?
5)how can i check this?
6)how can i check and solve this?
7)it's overflow type, with little hose connected to outside.
mark chandler
posted on 29/5/09 at 09:10 PM |
Try some water wetter, it really works!
bazz81
posted on 29/5/09 at 09:38 PM |
Sorry but what is water wetter???
Sorry im from holland....
edit: after google search i know...
ashg
posted on 29/5/09 at 10:08 PM |
the nissan micra rad has a much thinner core than the polo and clio units and is much less efficient.
also have you checked that the thermostat isnt stuck closed
another soultion could be to change the fan switch in the rad for one that turns the fan on at a lower temp.
[Edited on 29/5/09 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
A1
posted on 30/5/09 at 01:56 AM |
even with a micra rad, you should be okay, cause youre increasing the amount of cooling so much.
do all the pipes warm up okay? just give them a wee feel with the engine running up from cold.
if you try finding a service manual, itll tell you how to test the thermostat, itll be something along the lines of putting the probe into hot water
and measuring the values with a voltmeter
bazz81
posted on 30/5/09 at 10:33 AM |
At this moment the fan is switched so that it will run always, but it still get hot. I will check the thermostat this afternoon. When the coolant
indicator in dash of the original zx12 clocks indicates hot; blining. and you stand in front of the car, the fan blows cold air...
bazz81
posted on 30/5/09 at 12:56 PM |
thermostat removed, and cooked... but before boiling he opened, not measured as i dont have a device for it here. So may be waterpump but if the
inside of looks fine, then still the pump can be faulty i guess, you dont know if the pump is running ???
A1
posted on 30/5/09 at 03:20 PM |
im not sure how to check the pump is working other than checking that its the pipes all warm up, especially the engine outlet.
on the r1 engine, the water pump is accessed by the sump, its driven by the same shaft as the oil pump, so its quite a big job to get to it.
maybe if you put a section of clear tube into one of the cooling pipes so you could see if the water was flowing freely?
just an idea...
bazz81
posted on 31/5/09 at 06:37 PM |
Does anyone know if the waterpump fits al years of zx12's?? Or do i need a specific year of engine built; if so how can i find out which year
the engine was coming off?
Kosmo
posted on 31/5/09 at 07:15 PM |
My water and oil temps were high on my 1st drive, I then made a duct to ensure all the air has to pass thru the rad, this droped the water temp from
120°C to no more than 85°C and the oil from 125°C to max 101°C even in this weekends hot weather. I'm still stunned by the massive improvement !
bazz81
posted on 31/5/09 at 07:23 PM |
Hi could you made some clear pictures from the duct??
Kosmo
posted on 31/5/09 at 09:40 PM |
I'll take some tomorrow evening and put in my archive.
Kosmo.
Kosmo
posted on 1/6/09 at 09:22 PM |
Photos uploaded to my archive....
Kosmo.
bazz81
posted on 5/6/09 at 08:33 PM |
Thx cosmo for the pictures!!
How can i remove the waterpump?? i cant reach it, or do i have to lift the engine to get to the pump (hope not...)
