Triggerhappy
posted on 2/9/09 at 11:23 AM |
Fitting propshaft?
Is it common that ford style propshaft /to flange is a bit of in hole pattern?
I have some issues in fitting the "smaller" PDC70mm type of ford flange on propshaft to mating flange...seams holes are slightly of.
YES i do relize the pattern has uneven spread of holes but when placed aligned, still differs about 1-2mm in CC??
Common or not?
How would you go about it?...file prop bolt holes or?
Im from Sweden, so im escused...The Muppet drummer for president!!
James
posted on 2/9/09 at 11:44 AM |
Nah, just use Gripfill!
[Edited on 2/9/09 by James]
- Muhammad Ali
daviep
posted on 2/9/09 at 01:04 PM |
Should be a perfect match really, if this is a part which you have bought then if it is practicle I would return it to the supplier.
The "small" ford flange is a standard 1140 series flange as shown 2nd from the top on
THIS identification table.
If you can't return the part then I would re-bore and tap the flange correctly.
Davie
r1_pete
Sounds like you are trying to mix metric and imperial components, I wouldn't alter the holes, look for a correct flange, altering the holes
could lead to vibration and failure.
