chris_harris_
posted on 10/10/09 at 08:40 PM |
WTD Savage relay packs
I seem to have broken the switch pack on the back of my savage hazard switch, which is shorting it out.
does anyone have a spare that i can buy off them please.
Its only the little grey switch box, and i believe they are the same on all savage switches.
drop me a u2u if you can spare one.....
thanks guys
Regards Chris
Garage Clearout
posted on 11/10/09 at 08:39 AM |
it's a double pole switch, so why not use the opposite side of the block (if you haven't tried that already)
chris_harris_
posted on 11/10/09 at 09:43 AM |
i have done that already, its for the hazards so i utilise both sides, the pins seem to have come loose.
cheers
chris
Regards Chris
omega 24 v6
posted on 11/10/09 at 10:45 AM |
IF you could use one of your other double pole switches for the hazards then I MAY ( need to look) be able to supply you with a single pole unit with
3 contacts ( common, NC NO )
If that's of any use then let me know and I'll look tomorrow
chris_harris_
posted on 12/10/09 at 02:08 PM |
Omega 24v v6 you have u2u.
cheers
Chris
Regards Chris
