Author: Subject: Fuel gauge
philhoward
posted on 21/11/09 at 12:00 PM Reply With Quote
Fuel gauge
I have just taken my Tiger for a spin and the fuel gauge has started acting funny. When stationary it reads as it should do, but when moving the needle floats up and down like a clapometer. It has only just started doing this. I have checked earths and these appear to bo OK.
Any ideas?
Phil
tomgregory2000
posted on 21/11/09 at 12:04 PM Reply With Quote
that will be your fuel sloshing from side to side
mine does it
i can go from half a tank in a straight line to an almost full tank on a right hand bend and then to an almost empty tank on a left hand bend
[Edited on 21/11/09 by tomgregory2000]
philhoward
posted on 21/11/09 at 12:44 PM Reply With Quote
I do not think that this is the problem, as it has only just started doing it after 2 years of being OK
posted on 21/11/09 at 01:08 PM Reply With Quote
does it vary with engine revs - or with acceleration/braking and/or cornering.
can you be stationary and rev engine to see what effect it has.
also check battery voltage under same conditions.
what fuel guage is it? does the guage have a separate voltage regulator?
Daddylonglegs
posted on 21/11/09 at 01:10 PM Reply With Quote
Maybe you've got a baffle come loose? (As opposed to a screw )
Can you here anything rattling around in the tank if you rock the car from side to side?
philhoward
posted on 21/11/09 at 01:42 PM Reply With Quote
Al other gauges are OK. The needle does not move when stationary or when the engine is revved
It is a standard Tiger gauge. I am not sure if it has a seperate voltage regulator.
posted on 21/11/09 at 02:56 PM Reply With Quote
probs not - the older smiths guages had them.
so it does appear to be indicating the fuel - can you get the needle bounmcing if you rock the car?
usuallythe needel is damped to prevent that - electrically - so either someting has gone wrong in the guage or inside the tank.
