liam.mccaffrey
posted on 7/1/10 at 10:41 PM |
Expanded Neoprene
Hello, you guys never cease to amaze with the help you provide so here goes.
I need some expanded neoprene foam at least an inch thick and about a foot square.
Tried ebay, nothing I can see
Anyone have any laying around?
[Edited on 7/1/10 by liam.mccaffrey]
Build Blog
Build Photo Album
andrew-theasby
posted on 7/1/10 at 10:58 PM |
If its the stuff im thinking of, a model shop should have small bits of it if your near one. (like a dense rubbery foam?)
or maybe a garden centre knealing mat?
[Edited on 7/1/10 by andrew-theasby]
liam.mccaffrey
posted on 7/1/10 at 11:03 PM |
good thinking!
I have found a supplier of the 'proper' stuff, but I want locost
Build Blog
Build Photo Album
blakep82
posted on 7/1/10 at 11:09 PM |
ooh, could do with some of this myself
________________________
andrew-theasby
posted on 7/1/10 at 11:12 PM |
maybe
these?
austin man
posted on 7/1/10 at 11:34 PM |
What are you going to use the foam for??
trextr7monkey
posted on 7/1/10 at 11:45 PM |
Might have a sheet in garage - it is softer than the kiddies float stuff but is closed cell foam- possibly plastozate, will measure when I send the
dog to bed and report back
Mike
liam.mccaffrey
posted on 7/1/10 at 11:55 PM |
I need to build a custom vacuum box like this
They are for detecting pin hole leaks in weld seams.
soapy water on the seam will bubble in the vacuum if there is a pin hole
its like a bowl of water to find a puncture but in reverse
Build Blog
Build Photo Album
blakep82
posted on 8/1/10 at 12:17 AM |
i'm after some to put between the awesome stack of speakers i'm building up. to help dampen vibrations.
needs to be the kind of stuff you can easily squish between your thumb and finger. pool float stuff is too hard
trextr7monkey
posted on 8/1/10 at 12:49 AM |
tasteful olive green 28 mm x 465 mm x 995 mm
is there enough for both foam lovers ?
mike
liam.mccaffrey
posted on 8/1/10 at 01:21 AM |
how much do you need blake?
and thanks for looking
[Edited on 8/1/10 by liam.mccaffrey]
Build Blog
Build Photo Album
philhoward
posted on 8/1/10 at 07:43 AM |
Try Seals + Direct. They do it in strip form.
Linky
posted on 8/1/10 at 10:46 AM |
What, using a puncture to find a bowl of water ? If you find a cardboard box factory they use sheets of it behind the forms on die press machines.
wilkingj
posted on 9/1/10 at 08:34 AM |
Hmm what not fill the box with some parrafin with some fluroscene dye in it and slosh it about?
Just a thought!
Best Regards
Geoff
http://www.v8viento.co.uk
trextr7monkey
posted on 12/1/10 at 01:45 PM |
Chunk going in todays post
atb
Mike
