mcerd1
posted on 11/3/10 at 11:51 PM |
Help! - sierra lock barrel assembly
has anyone got a copy of the instructions for this before I make a mess of it
I've done it before a few times but that was too long ago....
[Edited on 11/3/10 by mcerd1]
skinned knuckles
posted on 12/3/10 at 12:00 AM |
i still have nightmares about the last one of these i did.
A man isn't complete until he's married, then he's finished
stevec
posted on 12/3/10 at 09:49 AM |
Its all on the web.
linky
Second link has how to read the key.
second linky
[Edited on 12/3/10 by stevec]
MikeR
posted on 12/3/10 at 09:59 AM |
how much does it cost to get the bits for a new barrel? Mine is a bit wonky and i've thought of replacing it before - this may be the cheaper
solution
mcerd1
posted on 12/3/10 at 10:26 AM |
cheers for the link
this would be easier if I had an old one to take apart, but having said that one of the tin-top ones is acting up now
I take it it doesn't matter where you put the springy spacer then ?
you get the whole barrel as a kit for £10 - £15 (everything thats in my pic above)
I got 2 new keys and the kit for something like £25 from ford
[Edited on 12/3/10 by mcerd1]
jonesier1
posted on 12/3/10 at 10:43 AM |
the springy spacer is the last spacer to go in,they're easy,tumbler then solid spacer and repeat,cap on and tap around to secure,line up the
grooves and rest pin in then put the little end in and insert into the barrel with curclip.![](/images//smilies/tongue.gif)
