Veszpremi
posted on 27/4/10 at 06:35 AM |
Duratec& gearbox
Hi all,
I'm planning to build an MNR Vortx RT based on a Duratec engine but I don't know whether I keep a traditional way and use the T9 box or go
for an MX5 6 speed gearbox.
Any help would be appreciated.
rgds,
Peter
posted on 27/4/10 at 06:42 AM |
Hi Peter
The MX5 box pattern is set, so that the engine leans very slightly to one side... not a big deal, but you will have to modify any 'normal'
Duratec engine mounts to suit.
Other than that, it seems to be a very highly rated box by those in the know... 6-speed, slick-change, 45kg (has integrated bellhousing, but still a
bit heavier than the Type 9) and can handle a fair bit of power.
I would say it's worth-it!
PS - Did those bits arrive?
It's Evolution Baby!
radom
posted on 27/4/10 at 09:39 AM |
I'd also compare their ratios
you can always upgrade N9 with aftermarket gear kit, not sure about mx5
[Edited on 27/4/10 by radom]
