Author: Subject: removing steering wheel
plantman
posted on 16/7/10 at 07:20 PM Reply With Quote
It's a long story but last weekend bleed the brakes and notice a slight movement in the ma ter cylinder bulkhead even though it is 1/8 plate!
So i need to weld in some supports either side of the brake master cylinder. no probs except..
i can't reach 'cos the steering wheel in the way
how do you remove the steering wheel sierra centre horn??
austin man
posted on 16/7/10 at 07:47 PM Reply With Quote
prise it out with a flat bladed screwdriver, undo the nut or bolt. Then pull like billyo you may need to give it a bit of a bash from underneath
McLannahan
posted on 16/7/10 at 07:48 PM Reply With Quote
Leave the nut on a few turns so it doesn't come off suddenly and twit you in the face!
plantman
posted on 16/7/10 at 07:50 PM Reply With Quote
do you mean prise out the horn?
DRC INDY 7
posted on 16/7/10 at 07:58 PM Reply With Quote
yea prise out the horn its a push in fit
Puddle Dodgers Club
austin man
posted on 16/7/10 at 08:02 PM Reply With Quote
always one spoil sport, I was waiting for the ooooh Ive smacked myself in the nose kinda moments
plantman
posted on 16/7/10 at 08:08 PM Reply With Quote
so let get this right
1 prise out the horn with flat blade screwdiver
2 wipe blood off nose wth oily rag
3 undo centre bolt
4 pull off steering wheel
5 wipe nose with oily/bloody rag
McLannahan
posted on 16/7/10 at 08:24 PM Reply With Quote
Pulling the wheel off will twit into your face...you're safe from the horn push unless you point the screwdriver towards yourself slip and then twit yourself with the end of the screwdriver!
plantman
posted on 16/7/10 at 08:37 PM Reply With Quote
so
2 undo centre bolt
3 pull off steering wheel
4 wipe nose with bloody rag
Stott
posted on 17/7/10 at 09:54 AM Reply With Quote
Originally posted by plantman
so
2 undo centre bolt
Not quite:
2 undo centre bolt
4 Quickly wipe car down in case any of the blood stains it
5 wipe nose with bloody rag
