posted on 9/11/10 at 10:02 PM |
Router Problems
I have a Belkin N Wireless Modem Router which has been working OK'ish for the last year. The connection to my daughters laptop though, has
always been a bit fickle, so I updated the router firmware which has now fixed the problem. Unfortunately since this update, my router now drops
connection to the internet whenever I use the phone (cordless DECT phone), although it reconnects as soon as the line is free.
Do any of you techie guys know if/how I can resolve this issue?
Phil
phoenix70
posted on 9/11/10 at 10:06 PM |
if your feeling techinical, try checking your master socket to see if the bell wire is still attached (google it) if it is, you don't need it so
just disconnect it. Also It may actually just be co-incidental that it started with a firmware upgrade, I would also try swapping out any
microfilters you have.
Scott
[Edited on 9/11/10 by phoenix70]
MikeFellows
posted on 9/11/10 at 11:02 PM |
Micro filters would be my first port of call
unless your running extensions from the master socket every socket must have one if something is plugged in
Scotty
posted on 10/11/10 at 07:21 AM |
as above, Microfilters
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
posted on 10/11/10 at 09:53 AM |
Yup. Swap the microfilter. I'd put money on that working.
posted on 1/12/10 at 05:43 PM |
Are some microfilters better than others? My other spare microfilter (same manufacturer) doesn't even work Any recommendations, or are they
all pretty much the same?
Phil
splitrivet
posted on 2/12/10 at 07:41 PM |
Is the Dect near the router if so move the base station away could be direct RF injection, if not filters.
Bob
