MikeR
posted on 18/11/10 at 05:37 PM |
What diff is in the ford kuga?
The ford kuga is available in 4wd. Anyone any ideas what rear diff they use?
Just wondering if ford have started producing another diff that will be available for kit cars in the future.
(or even started reproducing a diff used lots in the kit car world making more parts available)
matt_claydon
posted on 18/11/10 at 05:47 PM |
Doubt it would take the torque, most of these soft-roaders don't send much drive to the rear. Probably OK for a BEC, but not for a man's
engine.
MikeR
posted on 18/11/10 at 05:59 PM |
Main engine is the 2.0 TDCI and it takes up to 50% of the torque (10% under normal driving). The other engines they sell with it are the 2.5 v6 and
the 5 cylinder turbo from the RS. Should be able to take some torque.
If it is weedy then it will be idea for bec's.
matt_claydon
posted on 18/11/10 at 06:10 PM |
Ah, fair enough. The only similar vehicle I've seen the diff from is an X-trail and that looks puny as hell.
jonesier1
posted on 18/11/10 at 09:17 PM |
they use a hydrex clutch set up in the diff that is controlled via a can bus to a module from memory
im in my own little world...its ok though they know me there
James
posted on 18/11/10 at 11:49 PM |
Christ. This hobby of ours is doomed!
- Muhammad Ali
MikeR
posted on 19/11/10 at 12:07 AM |
I thought (from a very very brief) read that the hydrex unit was in the centre diff, not the rear diff.
bj928
posted on 19/11/10 at 05:01 AM |
my guess is that its the same rear axle as the x-type jag, seeing as it uses the same engine and gearbox option
matt_gsxr
posted on 19/11/10 at 02:37 PM |
X-type diff looks like this:
![](/galpreviews/x-ytpe_diff.JPG) ![x-type diff](/gallery/x-ytpe_diff.JPG) x-type diff
I suspect it is not alloy (or that they paint it rusty).
