Author: Subject: Locost Airbox?
RazMan
posted on 16/12/10 at 02:59 PM Reply With Quote
Locost Airbox?
Has anybody figured out a Locost version of the Piper PX600 airbox?
A remarkably simple design ... but a very complicated price
There must be a cheaper way eh guys?
Raz
interestedparty
posted on 16/12/10 at 03:12 PM Reply With Quote
Well it shouldn't be seeing any significant vacuum, (as you are using ITBs) so why not have a look around until you find some ready made plastic box etc that will fit the space available. Alternatively I suppose making something bespoke in GRPor ally is the way to go
blue2cv
posted on 16/12/10 at 03:29 PM Reply With Quote
I may have a spare similar arrangement kicking about somewhere, if i get chance i'll have a look if interested
Richard Quinn
posted on 16/12/10 at 03:43 PM Reply With Quote
I've thought about this type of thing and I'm sure, with mine being a V twin, I could use a modified butty box.
posted on 16/12/10 at 04:03 PM Reply With Quote
Same thought occurred to me - I'm sure there must be some suitably sized tupperware items
RazMan
posted on 16/12/10 at 04:48 PM Reply With Quote
You have my undivided attention Mr B
Raz
RazMan
posted on 16/12/10 at 04:51 PM Reply With Quote
You must have huge butties for your lunch, or maybe you have a 400mm long Sub Roll!
How about some form of trunking? - it would need to be (in my case) about 450mm long, 100mm wide & 50mm deep.
.... and I need 2 of 'em.
*edit* Found this but it's plastic and I doubt it would stand the heat NEW trunking cable wire tidy 50mm x 100mm 1M length on eBay (end time 28-Dec-10 14:00:43 GMT)
If I can make a buck, I could mould it with fibreglass
[Edited on 16-12-10 by RazMan]
Raz
MikeR
posted on 16/12/10 at 05:03 PM Reply With Quote
Trunking that size ......... sounds a bit like guttering to me.
RK
posted on 16/12/10 at 06:10 PM Reply With Quote
do a search. Steve H has a vid here somewhere showing what he's done in CF. He makes it look simple, which we know is not exactly the case!
martyn_16v
posted on 16/12/10 at 06:32 PM Reply With Quote
I spent several days making a buck to mould something similar, realised the shape I'd made couldn't release unless I made the mould in about five parts, and gave in and knocked one up in ally in about 3 hours
I'd still like to re-visit moulding one eventually, but it's not likely to happen any time soon.
RazMan
posted on 16/12/10 at 07:24 PM Reply With Quote
I found a really good video about making a mould - certainly LOOKS easy enough
http://www.youtube.com/watch?v=qKrl1PPvliQ
Some of the guttering profiles look good - I am thinking the 115mm half round cast ally might be useful. They even have end caps which simplifies things a bit but the trouble is there's going to be quite a bit of welding to graft on the intakes. It's a pity I can't use a TIG
Raz
Davegtst
posted on 16/12/10 at 07:43 PM Reply With Quote
Look at the state of his fingernails. Come on dude you're on TV.
username
posted on 16/12/10 at 08:29 PM Reply With Quote
You've obviously never met him if you think that's a bad state of fingernails, that's the cleanest he's Ever been!
MakeEverything
posted on 16/12/10 at 09:45 PM Reply With Quote
Could have had a shave and tidy workspace too!!
Kindest Regards,
Richard.
RazMan
posted on 17/12/10 at 11:02 AM Reply With Quote
If you need to mould a fully enclosed box (like an airbox) making a conventional buck would be impossible as you wouldn't be able to remove it. I was thinking about the possiblity of using candle wax as a buck, encasing the whole thing in fibreglass, then cutting the required holes and finally heating it up with a hot air gun to melt the wax - voila!
Raz
andrew-theasby
posted on 17/12/10 at 11:23 AM Reply With Quote
How about polystyrene too, wouldnt be as nice inside, but same idea. Acetone would dissolve it nicely!
RazMan
posted on 17/12/10 at 11:47 AM Reply With Quote
Aha! If you use polystyrene foam and wrap it in parcel tape, it will have smooth finish on the inside. 2 layers of heavy glass mat should do the job - a good hi-build primer will give a reasonable finish on the outside.
Raz
