Author: Subject: Type 9 bearings how to change them
M$RK_VXRD
posted on 27/2/11 at 07:13 PM Reply With Quote
I have asked this before but I can't find the post the search function seams to be on the blink again.
Which bearings do I need to mount the type 9 to the black top zetec when using zetec flywheel and clutch
Thanks in advance guys
[Edited on 27/2/11 by M$RK_VXRD]
austin man
posted on 27/2/11 at 07:39 PM Reply With Quote
Clutch Spigot Bearing Ford x-flow Pinto Zetec on eBay (end time 12-Mar-11 18:37:17 GMT)
M$RK_VXRD
posted on 27/2/11 at 09:42 PM Reply With Quote
Thanks Austin just bought it any advice on how to remove the old one?
snapper
posted on 28/2/11 at 07:34 PM Reply With Quote
You can just hook them out but another trick is to find an old input shaft or steel rod the same diameter, pack the bearing hole with grease push rod in this should make the grease get behind the spigot bearing and push it out.
If you get really stuck, chisel the inner bearing face until nearly through, it should break out.
Another thought.... A rawl bolt, these expand as you tighten, then pull out with a puller.
[Edited on 28/2/11 by snapper]
I eat to survive
I drink to forget
