Author: Subject: Low Beam... Tell-Tale Required?
posted on 4/3/11 at 06:48 PM Reply With Quote
Is a tell-tale light required for low-beam (MOT and C&U purposes only).
It's Evolution Baby!
posted on 4/3/11 at 07:02 PM Reply With Quote
Main beam warning light is required and in the nor far off future its operation is likely to become part of the MOT test.
johny p
posted on 4/3/11 at 07:16 PM Reply With Quote
no mate, im an mot tester and you dont need a low beam warning light only main beam. and its not coming into the test soon.
shaft
i fitted a side light tell tale for the IVA.
Reason:-
Because i have a digi dash fitted that illuminates with the ignition.
If you have traditional style guages that back light when the lights
are turned on it's not necessary, due to the gauge illumination
being acceptable as a warning light.
HTH,
Nick.
posted on 4/3/11 at 07:27 PM Reply With Quote
Perfect! Thanks guys!
posted on 4/3/11 at 11:08 PM Reply With Quote
You don't need a tell tale with them as it's not an offence to ride round with them lit all the time even in bright sunlight, nothing to do with the dash lights. Bikes have them coming on with the ignition for visibility reasons and cars have daylight running lights for the same. You don't see dash lights in daylight so they would not act as a tell tale if dip is on.
[Edited on 4/3/11 by Peteff]
username
posted on 5/3/11 at 01:34 AM Reply With Quote
Yet another pointless post, yet nearly informative...........
Daddylonglegs
posted on 5/3/11 at 07:34 AM Reply With Quote
How is it pointless? It's cleared up a question that is probably on more than one user's mind
posted on 5/3/11 at 08:06 AM Reply With Quote
You are confusing a tell tale light on the dash with DLRs ---- Day time Running Lights.
Macbeast
posted on 5/3/11 at 08:08 AM Reply With Quote
And how pointless is YOUR post ?
posted on 5/3/11 at 08:09 AM Reply With Quote
Reason:-
HTH,
Nick.
That covers the side (position) light warning there is no requirement for low beam warning tell tale only for the main beam and side/position lights.
johny p
posted on 5/3/11 at 09:19 AM Reply With Quote
britishtrident is spot on. hope thats cleared up everything for you pal?
