Author: Subject: Exhaust advice
Lightybob
posted on 7/8/11 at 11:47 AM Reply With Quote
Exhaust advice
I am looking to buy a new performance exhaust for my Locost 7. the engine is a Burton tuned 1300 Crossflow.
Does it need to have a heat shield for the SVA test?
Does anybody have experience/ advice on the best system?
I was looking at the CCR Chromerzone system from Europa, cost is approximately £250-£300,
I would like to do Hillclimbs, sprints and track days, the car is booked for SVA test on the 8th sept so it needs to comply.
Thanks David
Arthur T wareing
posted on 7/8/11 at 12:17 PM Reply With Quote
hi I have a 4into2into1 from a westfield I think its stainless as magnets don't stick it fouls the diagonal on my STMS and aries take it over the top rail so I have decided to make my own If you live within easy traveling distance you are welcome to try it for fit. Regards Arthur
Lightybob
posted on 7/8/11 at 12:40 PM Reply With Quote
Exhaust advice
Thanks Arthur
I have a 4-2-1 manifold it's the silencer that I am looking for,
Thanks David
scoop
posted on 7/8/11 at 03:29 PM Reply With Quote
Where are you?
Lightybob
posted on 7/8/11 at 03:55 PM Reply With Quote
Leeds, Monk Fryston
posted on 7/8/11 at 04:51 PM Reply With Quote
It doesn't need a heat shield. If you are going for IVA soon I would fit a nice quiet standard silencer to the car then look at a performance exhaust after you've passed.
Lightybob
posted on 7/8/11 at 05:46 PM Reply With Quote
Yes I thought about doing that, my present exhaust has a small split in the silencer and the tail pipe is does not have a radius
on the end, I thought that I might be able to have that welded, together with the correct radius on the end of the pipe. Is it
not possible to purchase a performance system that would improve performance and still conform to the IVA standards?
Thanks David
Ninehigh
posted on 7/8/11 at 07:38 PM Reply With Quote
Originally posted by Lightybob
Is it not possible to purchase a performance system that would improve performance and still conform to the IVA standards?
Thanks David
The two aren't necessarily inclusive.
For example IVA standards require a reverse gear, which bec gearboxes do not have. I'm not entirely familiar with the alternative used but I've heard they sap performance and thus "fall off" after the IVA..
Use a crappy quiet one for IVA then it complies, and it still complies when it "falls off" and is replaced with a performance one
franky
posted on 7/8/11 at 08:13 PM Reply With Quote
Thanks David
Of course it is however you're better off getting one made to suit your car.
