locost47
posted on 26/4/12 at 08:53 PM |
english diff
Hi guys just a question but can you mix & match splines & ring gear ie a 4.1 ring & a 3.89 worm obviously this gives a different ratio
but just wondered if its possible cheers
mark chandler
posted on 26/4/12 at 09:03 PM |
Afraid not, you need a matching pair.
daviep
posted on 26/4/12 at 09:06 PM |
No due to the fact that the size of the pinion and crown wheel do not change (much) across ratios the tooth pitch for each ratio is different and thus
won't mesh correctly with other ratios.
Davie
locost47
posted on 26/4/12 at 09:13 PM |
english diff
thanks guys
