posted on 11/6/12 at 02:23 PM |
Bonding Rubber to Exhaust Silencer!
Is it possible to bond a strip of rubber along the length of an exhaust box, or would the heat destroy the bond / rubber?
I only ask as I recently fitted a tow-bar (OE Land-Rover one!) to my Freelander and the back box hits it when the engine is running at low revs. The
chattering on start-up and reverse is doing my nut in!
Cheers!
It's Evolution Baby!
Mr Whippy
posted on 11/6/12 at 02:34 PM |
bad idea, it would melt or catch fire, the box can get very very hot in traffic jams etc, even burn off the galvi coating so rubber stands zero
chance
try loosing the exhaust joints and then twisting the pipes around, most joints have loads of slop. Or go and get longer rubber straps, there are
several lengths available (what I did with the bluebirds exhaust after I had the same issue), Halfords had a range
[Edited on 11/6/12 by Mr Whippy]
Ben_Copeland
posted on 11/6/12 at 02:35 PM |
Why don't you put rubber on tow bar where it's touching ? That why it's not always on contact with exhaust!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Daddylonglegs
posted on 11/6/12 at 02:53 PM |
I'm with Ben on this one
Slimy38
posted on 11/6/12 at 03:00 PM |
That's what I did with my old Cavalier, I put the rubber against the bit of chassis that it was banging against. It still melted a little bit
but it did work ok until I sold it to some unsuspecting victim.... ![](/images//smilies/bigsmile.gif)
posted on 11/6/12 at 03:51 PM |
Cheers guys... will see if I can shape some rubbery-stuff around the bit on the tow-bar that's catching.
The Shootist
posted on 11/6/12 at 04:06 PM |
Silicone
Silicone will handle the heat that far back from the engine.
