Author: Subject: oil cooler
pauladamss
posted on 18/6/12 at 11:47 AM Reply With Quote
oil cooler
Im thinking off putting an after market oil cooler on my gsxr indy is the internal oil pump man enough for the job if im putting the cooler at the front of the car or do i need to think about another oil pump?
matt_gsxr
posted on 18/6/12 at 01:54 PM Reply With Quote
The pressure drop across an oil cooler is small compared to the pressure drop across your engine.
So just use the standard pump. Mine is an 1100 but it works fine in this configuration.
pauladamss
posted on 18/6/12 at 04:28 PM Reply With Quote
What size cooler do you reckon will do the job 13row or bigger?
matt_gsxr
posted on 18/6/12 at 09:24 PM Reply With Quote
Mine is 235mm wide and 16 row, with a Mocal thermostat.
Not based on anything other than it looked about right!
I don't monitor oil temperatures.
Custardpants
posted on 18/6/12 at 10:56 PM Reply With Quote
I run a 16 row and get oil temp of around 85 degrees on the road with slightly more on track or in traffic. If you are worried about it I'd recommend the upgraded pump gear if you don't already have it(easy to put in behind your clutch plates)
pauladamss
posted on 19/6/12 at 09:41 AM Reply With Quote
im trying to sort out some aftermarket parts to join onto the engine at the mo and will probably go for the cooler that fits best under the rad.
