Author: Subject: barttery gone flat..any of these any good??
Ian Jones
posted on 28/3/13 at 06:29 PM Reply With Quote
Hi all, I have a vardy sealed battery, and it has gone flat today.
im guessing it is because i havent used it for the last month.
I have been looking at trickle chargers, and wanted to know if any of these were any good please.
1st.
a solar charger, this i would leave on the fence, and connect to the car.
+ free energy
-as safe to leave connected to battery??
http://www.maplin.co.uk/solar-powered-12v-12w-battery-charger-217850
2nd
ctek charger.
+ safe for battery
- have to have mains power supply
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_818863_langId_-1_categoryId_255205
what would the people of locostbuilders recomend please
thanks
ian
wylliezx9r
posted on 28/3/13 at 06:38 PM Reply With Quote
What makes you think the solar charger would be unsafe ?
George Best
Ian Jones
posted on 28/3/13 at 06:39 PM Reply With Quote
if it is left on for a week etc, could it over charge the battery?
maccmike
posted on 28/3/13 at 06:48 PM Reply With Quote
+1 ctek
Thurbs
posted on 28/3/13 at 07:00 PM Reply With Quote
+2 for the c-tek
Ian Jones
posted on 28/3/13 at 07:05 PM Reply With Quote
this is the battery spec, but going by the + it will be the ctek
the car is stored outside, under a stormforce cover, so i could run a extension lead from the shed, to under the cover.
SPEC:
Length - approx. 181mm
Width - approx. 77mm
Height - approx. 167mm
Weight - approx. 5.3Kg
Terminals - 12x12x1.2mm flat blade, 6mm diameter hole
Completely sealed Lead-Acid battery
Maintenance Free
PERFORMANCE @ 25°C:
Voltage - 12v
Capacity - 20Ah
Cranking current - approx 680Amps(5 secs)
The battery can be mounted on its side or upright.
Designed for motorsport use.
Westy1994
posted on 28/3/13 at 07:15 PM Reply With Quote
I was given one of those solar chargers a while back, I ended up binning it, unless you start from a 100% charge battery a solar one will not charge it in time for when you need the car, or at least if you dont plan on driving the car for a few months, they simply do not have the cabability to supply the current needed to charge a partial or flat battery. So with what you have given as an option, yet another one for the Ctec.
Eta
If you feel you are safer , get an decent ELCB circuit protector for use outside with your extension lead. BTW your batt specs are the same as mine, exactly, this was the battery I tried the solar charger on !
[Edited on 28/3/13 by Westy1994]
Ian Jones
posted on 28/3/13 at 07:22 PM Reply With Quote
thanks for the info all.
so it looks like a mains power supplyed one will be best.
is the ctek .8 a good vfm one, or would you recomend a defferent version/make?
thanks
ian
Westy1994
posted on 28/3/13 at 07:29 PM Reply With Quote
Your going to get lots of options now, lol, but my choice was this, one thing to remember is not to give a small capacity battery to much current, you wont get the life out of the battery otherwise, the one I choose was a small 900Ma one which is perfect for small batts.
eta
That link didnt give a price here's another one.
Ian Jones
posted on 28/3/13 at 07:30 PM Reply With Quote
lol, see what you mean.
is the ctek .8 a small enough charger?
[Edited on 28/3/13 by Ian Jones]
Westy1994
posted on 28/3/13 at 07:34 PM Reply With Quote
see above new link, bit cheaper that one
Westy1994
posted on 28/3/13 at 07:40 PM Reply With Quote
Yes 800Ma will be fine, will just be a tad slower than mine thats all.... I charge mine after every time I get home after a run, yes the alternator does this but to get it to peak again I use the charger, takes about 10 mins to get it to 100% again, then if I dont use the car for a month or so, I charge it every few weeks, takes around 5 mins then.
Ian Jones
posted on 28/3/13 at 08:27 PM Reply With Quote
if i got the ctek .8
and then got this charge indercator panel
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_738319_langId_-1_categoryId_255205#tab4
could the panel be used as a 12v power supply for sat navs etc as well?
thanks
ian
edited to say..
looking at it again, it looks like it is not a cig lighter style socket
Westy1994
posted on 28/3/13 at 08:42 PM Reply With Quote
To be honest, any decent 'intelligent' charger should already have the indicators on it, mine does, if you have to look at separate indicators , I would elsewhere than the one you are proposing ( thats assuming it does not have them - hard to see with the photo there, but it does have something on it)
As for the solar charger, I tested it to see what current it could supply, my own barely had the power to run three 10mm leds, now this was 2 years ago, maybe they are better now I don't know?. It may have the current to keep a satnav charged but I doubt it would have the capacity to run it wholey on that solar device.
If it were me, I would forget about the solar device and just get a decent charger with the charge state leds already built into it
posted on 29/3/13 at 09:49 AM Reply With Quote
Have you got any timer plugs. You could set it up to charge for 1 hour a day so it doesn't overheat the battery as even intelligent chargers are not perfect if left on for really long stints as found at the bike shop.
Ian Jones
posted on 5/4/13 at 04:28 PM Reply With Quote
I went for a ctek 0.8 in the end with a panel mounted display, so i can keep a eye on the levels with out having to connect anything up.
will post some pics when i fit it
Ian Jones
posted on 8/4/13 at 01:15 PM Reply With Quote
I fitted the batery indercator today, what do you think?
Ian Jones
posted on 17/4/13 at 06:03 PM Reply With Quote
the ctek charget turned up today
