doughie
posted on 19/5/13 at 08:59 AM |
Front Coilover Upper Mounting Bracket Position
Hi, looking to get rolling... needing some advice about where to position the upper mounting brackets for the front coilovers; have searched
photo's and every car seems different (outside edge of chassis rail/ under chassis rail/ multiple holes/ extended brackets... helppp)
What should i consider to make the decision?
thanks in advance for your thoughts/ advice/ sharing knowledge
doughie
posted on 21/5/13 at 06:44 PM |
any pictures anyone?
guess i need to get to a show to have a look at how it's done...
DIY Si
posted on 22/5/13 at 10:05 AM |
To a certain extent is will vary depending upon your wishbone design and shock length. Shock length will alter where on the top tube you need to mount
it, but aiming the shock at the tube centre line is the best option as it will reduce any twisting, if it's possible.
Sun Tzu, The Art of War
doughie
posted on 22/5/13 at 07:34 PM |
Many thanks DIY Si - will take a look...
