Author: Subject: Nylon joints in a coolant system?
ChrisLeary
posted on 28/6/13 at 08:17 PM Reply With Quote
Evening all,
I'm about to start plumbing my cooling system, my question is, in the 8mm bleed line from the thermostat, can I use nylon joints? I mean the barbed ones you can get from ebay.
The engine is a 2l silvertop zetec if it makes any difference.
Thanks in advance,
Chris
Don't force it! Get a bigger hammer...
posted on 28/6/13 at 08:46 PM Reply With Quote
The black plastic tees and joiners sold for fish ponds work OK -- you will find them on ebay the brass ones also on ebay are better though and cheap enough.
ChrisLeary
posted on 28/6/13 at 08:54 PM Reply With Quote
Ok, thanks for the info. I've bought the white barbed ones from autosiliconehose.com I assumed they'd be ok because they are advertised for use with water, but I guess heat and pressure might be a problem?
Thanks,
Chris
posted on 28/6/13 at 09:02 PM Reply With Quote
I have never tried them I just know the black ones work.
matt_gsxr
Not much heat (<120degC) or pressure (<1atm above ambient) in the coolant system.
Not that you'd think it when you remove a rad cap on a hot engine!
Scuzzle
posted on 28/6/13 at 09:25 PM Reply With Quote
They will be fine, these Davis Craig Electric Water Pumps are all nylon internals and are a lot thinner than a hose joiner.
ChrisLeary
posted on 28/6/13 at 09:26 PM Reply With Quote
Thats good information to know, thanks matt. I think I'll try them and see how I go. I can always replace them with brass ones if I need to.
Thanks to you both.
Chris
ChrisLeary
posted on 28/6/13 at 09:27 PM Reply With Quote
Brilliant,
Thanks mate,
Chris
me!
posted on 28/6/13 at 10:44 PM Reply With Quote
Thanks,
Chris
I'm using some of these, no problems so far.
