Author: Subject: 750mc Locost for sale
everest
posted on 25/7/13 at 11:25 AM Reply With Quote
CAR NOW HAS A NEW VARLEY REDTOP 20 BATTERY , NEW EBC GREENSTUFF FRONT DISC PADS , ONE FULL SET OF WETS ON FORD LAZER RIMS. VALVOLINE VR1 OIL, NEW SET OF NGK PLUGS AND AN ENGINE STAND. SPARES PACKAGE INCLUDES A £75.00 GIFT VOUCHER FOR A JAVLIN TRACKDAYS TRACK DAY, THIS SPARES PACKAGE IS AT A COST VALUE OF £670.00 +
READ ON FOR A MORE DETAILED DESCRIPTION - SPARES AND VOUCHER ONLY TO GO WITH THE CAR, NOT TO BE SOLD ON THEIR OWN.
Change of racing is the reason for sale , looking to get back into Drag Racing.
Locost Racing series Luego Chassis 1300 XFlow Locost, voted 7th most popular race series by UK Race drivers .Luego Locost, built by Mark White, Avo shocks, Ford Lazer wheels , Digi Dash 2 , Fire extinguisher serviced till March 2014 . Belts , Sabelt, dated 2015. There is a set of wet weather tyres on the same wheel rims with full tread and two tyres , used .
Engine is putting out approx 80BHP at rear wheels , only been run up to put on rolling road and to adjust valve clearences when hot. Tuned on the rolling road by Dave Bogg, renowned engine tuner and all round wealth of knowledge and expertise.
Gear box freshly rebuilt by an ex Ford touring car guy called Pete Fiddell ,who was part of the works Ford mechanics, working alongside drivers such as Andy Rouse !
Engine built by Ian Mittell,who with son Scott at the wheel won the 2011 , 2010 Locost championships, came in 2nd in 2009.( They are now racing in RGB race series) Ian designed a new sump for it, used New ARP bolts , Felpro head gasket, all the right bits you would expect from him to use, proffesionally bored and blueprinted, lots of parts from Burton Power., recipts for all spares and work done.
New high pressure oil pump from Burtons, new H&H Ignition set, new Brise starter motor .Alloy bonnet to aid cooling, foam filled tank, rear tow eye, plumbed in fire extingusher etc, all reay to race this year.
High back seat with head support , elbow bar as part of the cage.
Re packable stainless steel exhaust.
Fully adjustable AVO shocks front and rear.
4.1:1 rear driff , live axle and running the type 2 Ford gearbox, brand new rear mounting, new oil, with Molyslip.
Re cored radiator with an extra row.
K& N air filter
FilterKing fuel pressure filter and Redtop solid state fuel pump, new fuel pipe from tank to pump, pump to mid line where it meets the copper, then new to carb.
New steering column bush fitted
Digi Dash 2 , data logger, can be down loaded to lap top etc.
Folder of all above work done, plus much more and on the engine rebuild etc , contact names of suppliers and plugs, oils to use , contacts useful phone numbers, and a Locost T shirt (medium!)
Valued by the race series rep at £4500.00
There is no transponder fitted - this is how I bought it and they can be hired by the day for £35.00 from the club at race meetings - and maybe a quick respray - but only needed if you dont want to keep the same colours.
There is a small trailer with electrics but I will only sell this as an extra , but if you need one it would be £450.00 .
Thanks for looking.
Lack of time and other commitments means that i cannot race this year.
Please ring on 01482 654369 , Chris.
or email : kurisu@kurisu.karoo.co.uk
Cheers, thanks for looking.
