cryoman1965
posted on 10/11/13 at 10:13 PM |
Mondeo 1993 airbag control module.
Looking for an airbag control module for by poor 1993 mondy. Had it since it was a year old. Airbag light isconstantly on which is now an mot fail.
Anyone got one for a small amount of £s.
Nige
cryoman1965
posted on 10/11/13 at 10:19 PM |
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=50.jpg
Photo of said item.
[Edited on 10/11/13 by cryoman1965]
robocog
posted on 10/11/13 at 10:26 PM |
OOPS
Sorry Nige - forgot to ask at work
I have scrawled it on a piece of paper and will try to remember to look at it during the day as a reminder
(I would have written it on my hand - but its bath night - and its bound to be wet on the journey to work as per usual and will have worn off by the
time I get there and just be a smudged bruise mark :p )
You have my mobile - if you text me at any point tomorrow between 8 and 5:30 - it will jog my memory
If we don't have one in at work - I know we have a circle of banger boys who are quite partial to mondeo's call in regular enough to ask
around (its the sort of thing they possibly just toss into the car when they bring em back in for cubing)
Having said that - the season is now done with - so I cant promise one will turn up
Laters
Rob
pekwah1
posted on 10/11/13 at 10:40 PM |
i have a 1998 mondy i'm breaking, if the airbag control thingie's the same, you're welcome to it!
i'll check in the next couple of days for you
fazerruss
posted on 10/11/13 at 10:55 PM |
Nige
Are you sure its not the clock spring in the steering column (assuming it has one) . Sister in law had same problem with an escort. I cut out broken
bit and resoldered it . Worked perfectly. Bare in mind on some cars ( Ford may not be one of them) need an obd reset tool to turn off the air bag
light once the fault is rectified. BMW and Audi are like this.
"if assholes could fly this place would be an airport"
posted on 11/11/13 at 07:28 AM |
Not sure about the Mondeo but on most models Airbag light faults are 9 out 10 times due to bad connections in the under seat connectors.
The foam material used in the seat padding apparently releases chemicals the corrode the connectors.
snippy
posted on 11/11/13 at 08:05 AM |
I've definately got one of these. You're welcome to it FOC if you struggle with the others. Having owned a couple of Mondeos in the past I
have also encountered the air bag light issue. It had always been the yellow multi plug under the drivers seat. Pull it apart and clean the
terminals.
Nick
steve m
posted on 11/11/13 at 09:41 AM |
I also have had the light on, on a Rover 75 and my current 2008 mondeo
both cars were fixed easily by taking the multiplug apart under the seat, and soldering the wires together, and shrink wrapped
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
PSpirine
posted on 11/11/13 at 10:33 AM |
Just checked FYI - all Mondeo's 1993-2000 use this part number, except Japan, which has a different suffix. So any model year should give you a
module that works.
posted on 11/11/13 at 12:02 PM |
The other thing is check the fuse for the circuit has been removed to deliberately disable the airbag as a missing or blown fuse will cause the
light to come on.
On switch on the air bag control unit checks each circuit for a high or low resistance outside limits, if you suspect the clock spring is
defective you can test by disconnecting it under the cowl and substituting a 200 ohm resistor.
Usual caveats about working with air bags apply.
cryoman1965
posted on 11/11/13 at 01:45 PM |
Hi thanks for all the great replies. I will check out the plug under the seat before i see if i need to replace the module. Will let you know how
things proceed. Thanks for the kind offers.
Nige
cryoman1965
posted on 20/11/13 at 09:42 PM |
Snippy was kind enough to donate a module, I just needed to pay post. Unfortunatly it has to be from a 93 model or have the same serial number on the
module fitted to the car, the actual plugs were different.
So i am still looking for a module from a 93 mondeo. Anyone know of one available.
Nige
