Author: Subject: Charging a race battery
JacksAvon
posted on 16/3/14 at 11:29 AM Reply With Quote
Chaps,
does the collective have any thoughts on the best charger for a race battery.
I currently have a standard battery charger but I,m not sure if it is ideal for race gel batteries.
jack
serieslandy
posted on 16/3/14 at 01:18 PM Reply With Quote
Originally posted by JacksAvon
Chaps,
jack
I've got a cheapie lidl charger on my odyssey battery. I've done 2 charges as I'm only in my build stage and the battery seems fine
matt5964
posted on 16/3/14 at 05:29 PM Reply With Quote
had a standard optimate 3 on an oddesey 25 battery and it was not happy.. had to get a new battery now use a optimate 6 as its a pulse charger and has built in conditioning
sssline
posted on 16/3/14 at 07:18 PM Reply With Quote
I ended up buying a ctek mxs 5.0 , after lots of reading it seemed well suited.
Tony.R
https://www.facebook.com/groups/swkitcars/
supersport31
posted on 16/3/14 at 11:50 PM Reply With Quote
latest Optimate 6 is pretty trick, does everything but li-poly batteries
v8kid
posted on 17/3/14 at 07:17 AM Reply With Quote
Gell batteries need a slightly higher charging voltage to get 100% charge. You can use a normal battery charger but will only charge to around 80% capacity.
Quite a lot of marketing hype about battery chargers. Most battery chargers now are pulsed - it comes by default with the chip. My optimate battery is 5 years old, in good order, and I've always used a cheaop lidl battery charger. All I do is use the winter setting which is a slightly higher voltage. Proof of the pudding and all that stuff.
European safety directives ( or interpretations thereof!) mean battery chargers complying with regs won't work if there is no terminal voltage i.e. a dead battery!! On the other hand if you fully discharge your battery the life is considerably shortened so perhaps it is a good thing?
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
JacksAvon
posted on 17/3/14 at 09:47 AM Reply With Quote
many thanks chaps, time to go shopping
ashg
posted on 17/3/14 at 11:58 AM Reply With Quote
why would you need a special charger, do you think an alternator cares what battery is hanging off of it?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
supersport31
posted on 18/3/14 at 08:38 PM Reply With Quote
This is what i don't get about fancy lithium batteries. In the specs it always says you need a unique charger for them(that is not compatible with lead acid or gel batteries)
How come your standard automotive alternator can charge the lot with no issues ?
v8kid
posted on 19/3/14 at 07:49 AM Reply With Quote
Not a jot and that's the problem - well a bit of a problem it depends how nerdy you are . Most alternators are constant voltage whereas chargers are 3 stage.
The upshot is that an alternator will take hours, lots of hours, to get 100% charge whilst a variable voltage charger will do it quickly - as the actress said to the bishop.
In reality who cares or even notices if the battery only gets to 85% charge?
Most not but a few do and by the wonder of marketing hype that is extended to condition us all to buy.
Bit irrelevant since the chips are universal now and cheap apart from the problem of dead flat batteries .
Cheers!
