Author: Subject: leaking oil pressure/temp sender
Jodieshann
posted on 27/3/14 at 09:53 AM Reply With Quote
One of my senders is leaking. It's fitted around the sump area (can't quite remember exactly where it fits). As far as i can tell it's the threads that are not sealed. I was wondering if it's OK to use PTFE tape on the threads?
ChrisLeary
posted on 27/3/14 at 09:58 AM Reply With Quote
I think PTFE tape will be fine, I've used it on my sensors and had no problems, we use it at work daily on hydraulic systems too. Just try not to get it over the end other threads so that it doesn't tear off and get into the sump and possibly block things up...
HTH, Chris
Don't force it! Get a bigger hammer...
Jodieshann
posted on 27/3/14 at 10:17 AM Reply With Quote
Thanks - that was what i was thinking. I'll give it a go making sure not to tape too far towards the inside end.
gremlin1234
posted on 27/3/14 at 10:48 AM Reply With Quote
for a lot of sensors the block is the electrical ground. would only work with explicit earthing.
scimjim
posted on 27/3/14 at 11:25 AM Reply With Quote
Is it the threads, or is it coming from between the metal outer/plastic centre section?
ChrisLeary
posted on 27/3/14 at 11:43 AM Reply With Quote
Thats a very good point, my sensors are earthed back to the digital dash...
Chris
Jodieshann
posted on 27/3/14 at 02:55 PM Reply With Quote
yes - good point about earthing. I'll have to check that. Sounds like i need some more investigation as to exactly where the leak is coming from too. Do these things ever vibrate loose on a BEC engine?
