Nickp
posted on 8/2/18 at 08:57 AM |
Best chemical metal for fuel tank repair / patch?
Anyone had success repairing a fuel tank with chemical metal? If so which product please?
My Midas came with an unused custom made stainless fuel tank, roughly the same dimensions as a Mini van one. I fitted it but have since had trouble
drawing fuel from it even with 2 different electric pumps. Turns out someone had fitted an internal filter in a sealed tank!! And the pickup pipe is
loose and rattling round in the outlet fitting, so the pump was drawing more air than fuel. To find this out I've had to cut a dirty great hole
in the bottom of it. I now need to seal the pickup pipe into its fitting and patch the tank, hence the chemical metal question.
Ultimately I'll probably replace the tank but just want to get it on road / track ASAP for the smallest outlay.
Thanks in advance,
Nick
leon51274
posted on 8/2/18 at 10:01 AM |
I used petraputty with great success in sealing the top of my sender unit.
coyoteboy
posted on 8/2/18 at 01:52 PM |
Please don't stick your fuel tank back together - in the slightest deformation in an accident you'll be burned alive. It'll cost you
a tenner to get a local welder to patch it.
fazerruss
posted on 8/2/18 at 11:36 PM |
How big is the hole?
"if assholes could fly this place would be an airport"
Nickp
posted on 9/2/18 at 07:08 AM |
I can MIG it myself but doubt I'll get it to seal tbh. I presume TIG would be best?
Nickp
posted on 9/2/18 at 07:10 AM |
About 6" square, big enough to get in to sort out the pickup pipe.
fazerruss
posted on 9/2/18 at 08:56 AM |
Yes, to do it right TIG is best. Will need purging first with steam to get rid of petrol vapour so one doesn't loose ones eyebrows!
I do jobs like this from time to time. Even on plastic fuel tanks
Nickp
posted on 9/2/18 at 09:09 AM |
Cool, any chance you could do this one if I fetch it to you please? ![](/images//smilies/bigsmile.gif)
jps
posted on 9/2/18 at 11:52 AM |
Am I right in thinking you could also fill it with water before welding it up? Or - perhaps this is a bit too rustic - could you just ignite the
vapour in the tank to burn it all off? Assuming it is out of the car of course!
fazerruss
posted on 9/2/18 at 12:14 PM |
Igniting the vapour would be like setting off a small bomb.
It needs washing out with detergent and water then steam it with a wall paper stripper.
fazerruss
posted on 9/2/18 at 12:15 PM |
Post up a pic first of the hole
[Edited on 9/2/18 by fazerruss]
Mr Whippy
posted on 9/2/18 at 12:46 PM |
tried that with a Cortina tank, still ignited, tank leapt up off the floor and blasted water out the filler pipe with a big bang
Nickp
posted on 9/2/18 at 02:27 PM |
Here you go, stainless is about 2mm thick!!
![](/galpreviews/) ![](/gallery/)
fazerruss
posted on 9/2/18 at 02:41 PM |
Jesus that must be heavy if it's 2mm thick stainless.
Let me have a look to see if I have a piece big enough.
Nickp
posted on 9/2/18 at 02:55 PM |
Ha Ha, it bloody is heavy!! Do you want exact measurements? Whereabouts are you?
fazerruss
posted on 9/2/18 at 03:45 PM |
Yes sizes would be good. Im near Ferrybridge.
Nickp
posted on 9/2/18 at 03:50 PM |
It'd need a 7x5" piece to cover it.
steve m
posted on 9/2/18 at 04:55 PM |
why not use the bit that came out, and a fillet strip over the gaps ?
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Nickp
posted on 9/2/18 at 05:10 PM |
Because I had 2 attempts at getting the hole big enough, DOH!!
fazerruss
posted on 9/2/18 at 07:01 PM |
I have some stainless but it's only 1 mm. Should be plenty strong enough though unless you prefer like for like.
Nickp
posted on 9/2/18 at 07:10 PM |
I'm sure that'll be just fine mate
Can you please U2U me and let me know when you'll be able to have a bash at it.
Nick
